88 CRX suspension differences?
Old Jun 20, 2006 | 01:47 AM
OMG WTF's Avatar
Default 88 CRX suspension differences?
OK i know the front strut is a different size but what else is different? I am planning to swap the suspension to 89-91 spec but i need to know what parts are different. TIA.
Old Jun 20, 2006 | 02:09 AM
Wilson_'s Avatar
Default Re: 88 CRX suspension differences? (zclee.com)
rear lca is diffrent,88's are like the type RRRRR and the 89-91 are like everything else
Old Jun 20, 2006 | 04:32 AM
ludesrv's Avatar
88 suspension is different in the rear, everythign else are the same. BUT HF hubs on CRX HF are smalller and can only accept HF axles ends, but that can be swap with DX or Si suspension.
If your swapping the rear, think about doing the rear disc swap if your looking for the look/noise removal/easy serviceability. Basically, it's cooler, easier thing to work with, just doesn't stop as good. But rear discs are sweet. You can find them off 90-91 CRX Si or 90-93 Integras for the easiest swap. You can swap pretty much anything else at that point.
You can fit 5 lug type R suspension if you want.
The FAQ has alot of info on suspension swaps. Simply scroll down.
Old Jun 20, 2006 | 08:45 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zclee.com &raquo;</TD></TR><TR><TD CLASS="quote">OK i know the front strut is a different size but what else is different? I am planning to swap the suspension to 89-91 spec but i need to know what parts are different. TIA.</TD></TR></TABLE>
youd only have to switch out the rear lower control arm and shock. the rest is pretty much the same parts. the front shock is not any different really other than the brake line collar. its not a different size to my knowledge.
just got back from oahu yeah. gotta find me some spicy poke... wish safeway here in california had it....
Old Jun 20, 2006 | 12:11 PM
OMG WTF's Avatar
thanks for the info guys.
dude spicy tuna is relatively new to sushi, i love that ****!
Old Jun 20, 2006 | 02:24 PM
doublethink's Avatar
there are some good aftermarket setups that account for the difference in 88's
but if you really have your heart set on changing it, then by all means go for it.
Old Jun 20, 2006 | 05:38 PM
StorminMatt's Avatar
Contrary to polular belief, 1989-1991 suspension is functionally identical to 1988 suspension on a 1988 car. The only functional difference on 1989-1991 cars is the compensator arm mounting position.
Jay SWAT
Apr 3, 2009 04:13 PM
gob4show
Oct 2, 2005 04:53 AM
mechengine
Jun 5, 2004 08:16 AM
I3ackfire
11
Mar 17, 2004 09:19 AM
elusiveracing7
Apr 29, 2001 04:41 PM
