need some help 6th gen 5 speed conversion
im geting all the parts that im going to need for my 5speed swap but what i need to know is do i need the eng harness or can they just use my harness and the starter does it have to be from a 5speed and here i all the part that i have as of now
1.5speed tran
2.shift likage
3.ecu
4.shift pedales
5.center console
6.trans mount
7.clutch lines and hose
8.fly wheel
9.and just all the nuts and bolts
10.eng harness
so is there any thing that im missing let me know soon because im take my car down to hook-ups this week.......think for the help
1.5speed tran
2.shift likage
3.ecu
4.shift pedales
5.center console
6.trans mount
8.fly wheel
10.eng harness
2 seconds in the FAQ yielded: https://honda-tech.com/zerothread/1229014
it does not say that you can just use the 5 speed harness.and as well the starter is the 5 speed starter some thing that i have to have or can i just use the one i have now and do i have to use the 5 speed drivers side axle or can i just use my axle
You need the 5 speed starter. You also need the half shaft and axle for the driver side. As for as the harness, I'm not sure. I would just follow the guide.
Don't forget the actual clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm-fo-life »</TD></TR><TR><TD CLASS="quote">it does not say that you can just use the 5 speed harness.and as well the starter is the 5 speed starter some thing that i have to have or can i just use the one i have now and do i have to use the 5 speed drivers side axle or can i just use my axle</TD></TR></TABLE>
No, you need 5 speed axles.
ok thats one thing now what about the starter do i need the 5 speed starter and the harness i know in the link that you sent me he use the old harness now can i use the 5 speed harness or is it eazyer to use my harness
Though I have not yet performed this swap, my feelings are that if you want to take the time to use the 5-speed harness, it could be done. However, I feel that it would be easier to stick with the current harness and follow the wiring guide provided in the Auto-->Manual swap guide.
As stated earlier and posted in the swap guide, yes, you need the 5 speed starter. Also a quick note for you, please research on your own, especially when this topic has been covered many many times, it may save you from some flaming.
allanonjj
Mar 27, 2007 11:08 AM
antiJDM
Oct 11, 2004 01:28 PM
