FS: GSR Darton Extended Deck Stroker block, Eagle rods, OBX Cam gears, Moroso Pan, crank n more
Old Jun 19, 2006 | 11:12 PM
totalimpact's Avatar
Default FS: GSR Darton Extended Deck Stroker block, Crower rods, OBX Cam gears, Moroso Pan, crank n more
Please read the ENTIRE message here - I do not own this stuff, contact the email address below if you are interested-
Some may have seen my thread trying to get this figured out - I was going to buy this setup, but I give up, I just cant afford all the stuff to put this together, so its up for grabs -
contact buzz benes snobrdrskatr@msn.com - he has lots of parts up for grabs -
GSR Block with 83mm Darton sleeves and 3/4" deck extension
Correct extended Crower rods for this application
Moroso Oil pan with oil return fitting for turbo and built in windage tray
OBX adjustable cam gears
83mm cometic head gasket
B18C1 crankshaft
Block guard
Heres a link to those rods for specs:
http://www.racepartsdirect.com...=3611
I think all you need to make it complete is some pistons, (I have a set of 84mm Arias if anyone is interested), like a ~93mm stroker crank and either an electric water pump kit or a bigger timing belt. big possibilities here at a deal.
I have no connection with this guy, I found the stuff on ebay, below is the original link, he just seemed cool and in need of cash, so I thought I would give him a hand since people seem so interested here.
http://cgi.ebay.com/ebaymotors...S%3A1
Modified by totalimpact at 11:58 AM 6/20/2006
Old Jun 20, 2006 | 10:35 AM
96 GSR-T's Avatar
Default Re: FS: GSR Darton Extended Deck Stroker block, Crower rods, OBX Cam gears, Moroso Pan, crank n more
Bump for a buck nasty block.... someone jump on this !!!
Old Jun 20, 2006 | 11:00 AM
dont PM me people- I dont own this stuff, just doing a favor for this guy - his email again if you failed to read it in the post above is -
Keep us updated if anyone tackles that block I would like to see it in action
Old Jun 21, 2006 | 09:39 AM
you know you want it
Old Jun 22, 2006 | 04:38 PM
b
jeffface
Northeast (Sales)
Oct 20, 2013 09:45 PM
JDM IS OEM
Northwest (Sales)
May 27, 2007 08:09 PM
AllMotor12s
May 5, 2007 10:34 AM
spooledex
Dec 22, 2006 11:13 PM
mymeatb18"
Dec 16, 2005 06:39 PM
