overheating problem..
Old Jun 19, 2006 | 08:58 PM
kyden's Avatar
Default overheating problem..
ok 99 civic dx, ls-t..
the car overheats at idle on hot/humid days, but if i rev it, the temp goes right back down. and it does it if i am on the highway over 4000 rpm. the temps are fine at night, zero problems.
anyone have any idea whats wrong? i don't think thermostat cause both upper and lower hoses get hot. are these symptoms of a clogged radiator? water pump?
i doubt its a headgasket cause wouldn't it overheat all the time then?
Old Jun 19, 2006 | 11:44 PM
4cylsturbo's Avatar
Default Re: overheating problem.. (kyden)
did you check all of your grounds? my car had the same problem and found out that it was a bad ground.
Old Jun 20, 2006 | 07:26 AM
kyden's Avatar
Default Re: overheating problem.. (4cylsturbo)
grounds are good. fan is operational.
Old Jun 20, 2006 | 07:48 AM
JDM knowledge's Avatar
sounds like a water pump. Not competely positive, but your also boosting and i know nothing about boost problems. Not saying its an isolated boost problem but...you get what im saying.
Modified by JDM knowledge at 9:20 PM 6/20/2006
Old Jun 20, 2006 | 09:28 AM
Crazydave's Avatar
Default Re: overheating problem.. (JDM knowledge)
1.) Pressure Test your system
2.) Pressure Test your cap
3.) Flush your radiator
It could be water pump or radiator
This sounds stupid, but make sure nothing is blocking your radiator.
Old Jun 20, 2006 | 10:55 AM
parceroreal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyden &raquo;</TD></TR><TR><TD CLASS="quote">ok 99 civic dx, ls-t..
i doubt its a headgasket cause wouldn't it overheat all the time then?</TD></TR></TABLE>
i'm in the same boat right now on my 96 accord...
i've changed everything form t-stat to rad cap to fan relays and the symptoms are same as yours...
i was told that there was coolant in the emmissions...head gasket needs to be replaced...
Old Jun 20, 2006 | 05:52 PM
97grnrs's Avatar
Default Re: overheating problem.. (parceroreal)
try to bleed all air out of system.. also on mine since my turbo is close to radiator i had to make up some custom" heat shields out of sheet metal. i bent them around the mani and turbo and that stopped my overheating problem completely. i think it was heat soaking the rad b 4
Old Jun 20, 2006 | 09:25 PM
x2ooo's Avatar
what kind of computer are you using?
Ryebread1974
Sep 24, 2018 04:24 PM
MFButler
Mar 11, 2010 11:30 AM
sgergg454
Jun 7, 2006 03:13 PM
J1A1H
18
Jan 8, 2006 12:13 PM
CroSi
11
Aug 24, 2004 12:58 PM
