Brake Kits for CRX?
Old Jun 19, 2006 | 07:12 PM
SINISTR's Avatar
Default Brake Kits for CRX?
hey guys.
Wandering if anyone here has rotor/caliper replacements for their gen2 (87-91) CRX and where you got them from?
Brembos or the like? any contacts?
thanks
Mike
Old Jun 20, 2006 | 11:19 PM
SINISTR's Avatar
Anyone? is everyone driving on stick rotors and calipers?
Old Jun 21, 2006 | 03:44 AM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
Default Re: (SINISTR)
http://www.fastbrakes.com
Old Jun 21, 2006 | 04:00 AM
sierrakilo's Avatar
I added the FastBrake big brake upgrade kit on my 89 Civic Si and I really like the performance. I've done both the front and rear kits, although you probably don't need the rear disk conversion unless you're racing, or you really need to rebuild everything on the rear, which is what I needed. The front kit alone adds much more stopping power with the 11" rotors and the larger Integra calipers. Highly recommended IMO.
Old Jun 21, 2006 | 05:32 AM
tommycrx's Avatar
Default Re: (sierrakilo)
I've got the 11" rotors / Wilwood calipers setup from Fastbrakes, and would recommend them highly. Rear brakes are stock.
Old Jun 21, 2006 | 05:41 AM
CRXBart's Avatar
Default Re: Brake Kits for CRX? (SINISTR)
I have EX spindles, Accord wagon calipers, and prelude VTEC rotors redrilled in the front, with stock disc in the rear, it stops great. Kits are over rated and over priced. You can achieve the same thing with a few hours junkyard shopping. Make sure you upgrade your MC too.
Old Jun 21, 2006 | 05:59 AM
ludesrv's Avatar
Default Re: Brake Kits for CRX? (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">I have EX spindles, Accord wagon calipers, and prelude VTEC rotors redrilled in the front, with stock disc in the rear, it stops great. Kits are over rated and over priced. You can achieve the same thing with a few hours junkyard shopping. Make sure you upgrade your MC too. </TD></TR></TABLE>
https://honda-tech.com/zero...age=1
There you go. One of the cheapest/best upgrades you can do to braking.
PS: Rear discs are overrated. They do not stop/hold as good as drums. They also add weight. They aren't neccesary for racing at all, whoever said that. They are more or less for show. I'd do it, cause it looks better then drums, and it's easier to service then drums...******* springs.
Old Jun 21, 2006 | 08:14 AM
EF_ST@TUS's Avatar
Default Re: Brake Kits for CRX? (ludesrv)
Just finished installing 90 integra complete knuckle/hub. Everything works great partially because tyson came over last night
I have th rear disc also works great also, although i still need the 15/16 mc/booster.&lt;----- has anyone got this from fastbrakes? Does it come together? (mc/booster)
Old Jun 21, 2006 | 08:17 AM
ludesrv's Avatar
Default Re: Brake Kits for CRX? (Lost_in_a_world_so_cold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold &raquo;</TD></TR><TR><TD CLASS="quote">Just finished installing 90 integra complete knuckle/hub. Everything works great partially because tyson came over last night
I have th rear disc also works great also, although i still need the 15/16 mc/booster.&lt;----- has anyone got this from fastbrakes? Does it come together? (mc/booster)</TD></TR></TABLE>
Go buy the EX one for 90-91 civic 4 dr. 15/16 FTW.
Old Jun 21, 2006 | 08:18 AM
EF_ST@TUS's Avatar
From where?
Old Jun 21, 2006 | 08:21 AM
ludesrv's Avatar
Default Re: (Lost_in_a_world_so_cold)
Any parts store. I'm gonna get mine from PartSource. NAPA would for sure have one, maybe not in stock, but they can get one.
Old Jun 21, 2006 | 08:26 AM
EF_ST@TUS's Avatar
It would be the same as fastbrakes only more $$
Old Jun 21, 2006 | 08:40 AM
FakeJDMEF8's Avatar
what does the ex spindle look like.?
i just landed a 89 Si that im going to completely redo....
so on my car, the 89, i need the ex spindles, 15/16 mc, prelude rotors, and Wagon calipers????
Old Jun 21, 2006 | 08:54 AM
JG90CRX-Si's Avatar
Default Re: (FakeJDMEF8)
I will be doing the ITR Calipers with 11" rotors soon (just ordered the rotors yesterday) so once I get a chance I will install these and show pics!
I purchased some reman calipers/pads new from someone (not a shop) here in Houston and they look great!
I would look into buying some of these as there not that expensive and I'm getting the Brembo rotors (front only) shipped to my place for $90.
JG
Old Jun 21, 2006 | 08:56 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FakeJDMEF8 &raquo;</TD></TR><TR><TD CLASS="quote">what does the ex spindle look like.?
so on my car, the 89, i need the ex spindles, 15/16 mc, prelude rotors, and Wagon calipers????</TD></TR></TABLE>
using the EX knuckles gives you the same rotor and caliper as the DA integra. its different than using just the whole DA knuckle because the EX knuckle is otherwise the same as any EF knuckle, whereas the DA knuckle is a bit taller and heavier. its still useable, but keeping the rest of the suspension geometry the same is ideal. its jsut harder to find since they only came from 90-91 4dr EX sedans, and also ive heard the original hubs & bearings(?) are discontinued, not sure what ppl are doing about that.
the 15/16 mc is recommended because of the extra size of the caliper piston. it makes the brake pedal stroke very long.
the prelude rotor and wagon caliper is a hack to fit an even bigger rotor and caliper. not really necessary, but it basically achieves the same thing as the ITR brakes.
Old Jun 21, 2006 | 08:59 AM
JG90CRX-Si's Avatar
Default Re: (JG90CRX-Si)
Oh yea, I've already had the steal braided lines, slotted rotors and pad kit on all four corners for some time now but that was stock size. This kit worked great too and cost at the time (2000-01) like $450?
Good luck
JG
Old Jun 21, 2006 | 10:53 AM
HT Chaplain's Avatar
Loved
Default Re: (o-man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o-man &raquo;</TD></TR><TR><TD CLASS="quote">http://www.fastbrakes.com</TD></TR></TABLE>
thats what i got
Old Jun 21, 2006 | 10:04 PM
SINISTR's Avatar
mmm... good advice there guys. Im not sure what I wanna do yet - i'll have to see what is the best bang for the buck and maybe save a little more.
Only thing im thinking of is that EX 4dr sedans you guys refer to... civic yeah? don't know if we got them here... never seen an 'EX'?
blazzer
10
Feb 27, 2010 10:43 AM
sjbmx
Jun 11, 2008 03:41 AM
litlekikr
28
Jan 14, 2004 03:05 PM
bseriesboosted
Sep 22, 2003 08:30 PM
D-Man
Mar 4, 2002 04:48 PM
