Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
DIY: Ingalls "SmartArm" and "FastCam bolt" Camber Kit
Old Jun 19, 2006 | 04:33 PM
scansel912's Avatar
Default DIY: Ingalls "SmartArm" and "FastCam bolt" Camber Kit
Ingalls Front and Rear Camber Kit DIY
Tools Needed:
2 10 mm wrenches
17 mm socket and wrench
18 mm socket and wrench
19 mm socket and wrench
Jack and jack stands
Torque wrench
Air wrench if you have one and swivel ends (Makes life easier)
I decided to do a front and rear camber kit DIY seeing that there wasnt' too much info on how to install them even though it is a really easy install. First, this is what I got in the mail, two Ingalls "SmartArm" Adjustable camber bars for the rear (rubber bushing model) and two Ingalls "FastCam" Adjustable camber bolts for the front. This kit will provide up to + or - 4 degrees of camber in the back and + or - 2 degrees in the front. My car is a 2001 Civic Ex with Neuspeed Sport Springs (1.75" drop).
We'll start with the rear first since that seems to be the most difficult, jack up your car and take off your wheels and tires.
Heres what you should see, or something similar (I had an existing camber arm but the OE looks similar except its not adjustable)
First, you want to remove the 10 mm bolt and nut on the ABS bracket to remove it from your old upper support arm, or in my case, my old camber bar.
Then, remove the two 17 mm bolts from the upper support arm that are mounted to the upper under portion of the wheel well. You will be needing to reuse these bolts so be careful.
Next, remove the 19 mm nut and 17 mm bolt from the outer end of the upper support arm to finally remove the upper support arm assembly.
Now it's time to install your new Ingalls camber kit. Heres what it should look like before you fasten it all together. Refer to this picture on which way everything attaches. Compare your newly put together camber arm with your old OE one and try to get it to the same length for the time being until you can take to an alignment shop to get fully adjusted.
First, attach the bracket end of the arm onto the spindle using your old bolt and new nut and washer supplied with your kit. Torque to 43 ft/lbs.
Then, I found it easier to install the OE ABS bracket while you can still move the camber arm around. Use your existing screw and new nut supplied in the kit and hand tighten with two 10 mm wrenches. Its somewhat tricky so have patience.
After installing that, bolt in the other end of the arm using the OE bolts. You have to jack up the lower control arm to compress the suspension, or else your bolt holes will never line up. Tighten to 43 ft/lbs as well. You are now done with the rear of the vehicle :rockon:
Front "FastCam" Camber Bolts
You will notice when you get these bolts, that they aren't as wide as the stock bolts, but have a cam in the middle. This cam is offset with the bolt and provided the camber adjustment. Ive never really dealt with these before the install so I don't know much about them so I just tried following the instructions best I could. There are two sizes available to order, 14 mm for 01-03 and 16 mm for 04-05 I believe so remember to order the right one or it won't fit.
First, raise the vehicle at the jack points underneath the body.
Next, remove the upper strut bolt circled in the picture but NOT the lower one using a 19 mm socket and wrench.
Next assemble your fastcam bolt and washer like this in the picture. The instructions were a bit confusing, but this is how I interpreted it.
The instructions say to add positive camber, have the bolt arrow pointing towards the engine while having the washer handle towards the tire. Like I said before, just guess until you can have your car properly aligned.
Next, loosen the bottom strut bolt a bit so the top one can be rotated. Insert the bolt the same way the stock one was with the washer between the strut and bolt head. Remember to keep the bolt arrow pointing towards the engine
and the washer tab towards the wheel for positive camber. I found it best to hold the bolt head with a 15 mm wrench and torque the 18 mm nut so the bolt head won't move. Torque to 76 ft/lbs.
Now my car is only lowered 1.75", so camber adjustment for the front is minimal. If you need more positive camber, remove the bottom strut bolt next and repeat the same procedure except for this time, point the bolt arrow towards the tire and washer tab towards the engine. But like I said before, if your unsure, make and educated guess until you can take to an alignment shop in which they can dial in your car to your specs.
I will soon get my car aligned and will report back to you guys ASAP!
Old Jun 19, 2006 | 05:10 PM
UNBRE4K4BLE's Avatar
Default Re: DIY: Ingalls "SmartArm" and "FastCam bolt" Camber Kit (scansel912)
great DIY may i ask where you got the camber kits from and the cost? i also have an 01 EX lowered with neuspeed sports....i haven't felt the need to get camber kits yet, but it certainly wouldn't hurt...
Old Jun 19, 2006 | 06:09 PM
scansel912's Avatar
I PM'd you Freshtodef
Old Jun 20, 2006 | 03:06 PM
scansel912's Avatar
Bump, http://www.dezod.com has them for sale!
Old Jun 20, 2006 | 03:58 PM
fventura03's Avatar
you already had a camber kit, i guess you bought that one because your old one was rusty?
its the same thing, different design...
Old Jun 21, 2006 | 05:29 PM
scansel912's Avatar
Bump for any questions?
Old Jun 21, 2006 | 05:57 PM
fventura03's Avatar
mine was a question
Old Jun 22, 2006 | 04:17 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: (fventura03)
lol
Old Jun 22, 2006 | 08:10 AM
scansel912's Avatar
Any intelligent questions is what I meant.
I obviously did not buy a second camber kit for my health. I'm just trying to help Ingalls spread the word and help people out if they need help with installs.
Old Jun 22, 2006 | 08:25 AM
fventura03's Avatar
i believe mine to have been an intelligent question. what purpose does it do for you to buy a new camber kit when you already had one. aside from your old one being rusted over i dont see a reason to replace it.
looks like you had an ingalls before, i'm guessing the new one will look like that in a couple of months/years.
sorry to say it, but my SPC doesn't look that bad, after 3yrs. it was a simple question, no need to be an *** about it
Old Jun 23, 2006 | 02:32 PM
scansel912's Avatar
Haha... But what I'm trying to say is, is that I didn't buy it, I installed it for Ingalls just to help people out on the forums and make them aware of the product and what it takes to install it.
Old Jun 26, 2006 | 01:30 PM
robstamina's Avatar
Default Re: (scansel912)
He had the old kit which is welded and NOT powder coated hence the rusting..
New one is forged(WAAYYY stronger than welded)
and powdercoated for no rust!!
Old Jun 28, 2006 | 03:04 PM
scansel912's Avatar
Thanks Rob for the clarification!
Old Sep 15, 2007 | 07:51 PM
kierdevin's Avatar
Great DIY, thanks, this will help alot...
Old Sep 15, 2007 | 08:08 PM
Droidism's Avatar
Pretty cool. Thnx for the wright up.
Old Sep 15, 2007 | 08:40 PM
Honda Rules's Avatar
yeah great job
Old Sep 15, 2007 | 09:15 PM
sil04ver's Avatar
205/50/15?
Old Sep 16, 2007 | 07:33 AM
LatinEM2's Avatar
pretty nice DIY, nice color also! hehe
Old Sep 16, 2007 | 06:13 PM
skipbarber's Avatar
i agree with fventura, ive have my SPC kit for 5 years and it's not even close to being that rusty, infact, about 98% is still black. I can adjust camber on them now as i did back when i first put them on my car.
Old Sep 16, 2007 | 08:02 PM
kcari's Avatar
Default Re: (skipbarber)
how come some people say you need a camber kit while others say you don't. some say its all about toe. whats up with that???
Old Sep 16, 2007 | 08:12 PM
toyomatt84's Avatar
Sanji
Default Re: (kcari)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kcari &raquo;</TD></TR><TR><TD CLASS="quote">how come some people say you need a camber kit while others say you don't. some say its all about toe. whats up with that???</TD></TR></TABLE>
First link in the FAQ's: https://honda-tech.com/zerothread/2084043
Old Sep 17, 2007 | 06:28 AM
K24_Y61P's Avatar
awesome write up. i got the same kit front and back for my car. too bad you didnt do this earlier got ate from the tire place for 160 bucks to put it on. i would have myself but i just got my wisdom teeth out and really was not in the mood. but awesome!
Old Sep 17, 2007 | 07:24 AM
1llmatic's Avatar
New User
Default Re: DIY: Ingalls "SmartArm" and "FastCam bolt" Camber Kit (ajgrosch716)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajgrosch716 &raquo;</TD></TR><TR><TD CLASS="quote">...too bad you didnt do this earlier got ate from the tire place for 160 bucks to put it on...</TD></TR></TABLE>
Original Poster - scansel912
Title - DIY: Ingalls "SmartArm" and "FastCam bolt" Camber Kit
Time and Date of Post - 8:33 PM 6/19/2006
Maybe there should be a DIY on How to use the Search on Honda-Tech.com
Archived Content is KEY!
Old Sep 17, 2007 | 09:10 AM
sil04ver's Avatar
already asked, but whats that rim and tire size?
Old Sep 17, 2007 | 11:52 AM
K24_Y61P's Avatar
Default Re: DIY: Ingalls "SmartArm" and "FastCam bolt" Camber Kit (1llmatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1llmatic &raquo;</TD></TR><TR><TD CLASS="quote">
Archived Content is KEY! </TD></TR></TABLE>
hahaha
