whats better to use for my setup....2.5" or 3" intercooler and hard pipe
Old Apr 16, 2002 | 09:59 PM
NeXtLeVeL_TyPe_R's Avatar
Default whats better to use for my setup....2.5" or 3" intercooler and hard pipe
hello i was wondering if someone could help me...
I have a 2001 ITR.
I am currently building a custom turbo setup on it.
I have a Garrett T04 turbo and starion intercooler and bunch of other goodies
I have a Ericks 70mm TB and STR intake manifold
what piping should i use for the intercooler to the TB
what piping should i use for the intercooler to the Turbo
Will it hurt if i go with 3" piping or will it help???
the 2.5 pipe i have seems too small to go to my TB
thanks for any replies
Old Apr 16, 2002 | 11:48 PM
sparkz's Avatar
Default Re: whats better to use for my setup....2.5" or 3" intercooler and hard pipe (NeXtLeVeL_TyPe_R)
2.5" should be fine from intercooler to TB. bigger isnt always better. But since you have a starion intercooler, something like 2.25" would be better for moderate boost levels. 3" is jsut too big for that intercooler
Old Apr 17, 2002 | 09:37 PM
Default Re: whats better to use for my setup....2.5" or 3" intercooler and hard pipe (sparkz)
Thanks for the reply
well i am in the process of modifying the end tanks for a side exit rather then the starion top exit....I plan on making the end tanks open up more cause the starion like you said is only about 2.25.... Even by doing that you still think that i should shy away from 3" Only cause it seems like that TB and manifold would be starved with a 2.5.... but thats only my logic, thats why i ask cause i would appericate a second opinion
Old Apr 17, 2002 | 09:38 PM
Smashback's Avatar
Most kits use 2.25" piping. I used 2" and stepped up to 2.5 after the IC.
jdm inc
Jul 30, 2006 12:38 AM
0ptimus prime
Welding / Fabrication
10
Mar 6, 2005 06:30 PM
DubyaAye
Apr 25, 2004 10:54 AM
TurBoXBirD16
May 29, 2002 10:44 PM
