will a 92 hydro clutch work with my 89 dx cable tranny?
Old Jun 19, 2006 | 11:27 AM
akteamster's Avatar
Default will a 92 hydro clutch work with my 89 dx cable tranny?
i swapped long blocks and would like to use the fresher clutch on the 92 block with my 89 cable tranny as opposed to the beat stock clutch dat came with the 89 dx...will it work ?
i searched and most only covered DA clutches...not much info about EF compalibilty
Old Jun 19, 2006 | 11:36 AM
ludesrv's Avatar
I'm 99.9% sure it won't work. Spline count.
Old Jun 19, 2006 | 11:40 AM
akteamster's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">I'm 99.9% sure it won't work. Spline count.</TD></TR></TABLE>
damn! now i have to pull the tranny again and swap the clutches!
can anyone verify this????????!
bag's Avatar
bag
i know it will work in the 90-91 tranny and it wont work in 88 tranny, but 89 tranny im not 100% sure
Old Jun 19, 2006 | 11:57 AM
ludesrv's Avatar
Honestly tho, why didn't you buy a new clutch? Cheap noname aftermarket ones are less then 100$.
Old Jun 19, 2006 | 12:01 PM
akteamster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Honestly tho, why didn't you buy a new clutch? Cheap noname aftermarket ones are less then 100$.</TD></TR></TABLE>
because it didnt occur to me untill now and i was trying to get the car up and running ASAP as it is my daily driver.
now i will have to pull the tranny and slap in the original stock clutch, but i dont have the alignment tool....can these be purchased at any autoparts store?
Old Jun 19, 2006 | 02:29 PM
akteamster's Avatar
Default Re: (akteamster)
bump for some anser
Old Jun 19, 2006 | 03:13 PM
crxblues's Avatar
it should work. 88 trannys have 21 splines and 92 trannys have 20 splines so 89 should be 20 splines im 99% sure
Old Jun 19, 2006 | 08:42 PM
akteamster's Avatar
Default Re: (crxblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxblues &raquo;</TD></TR><TR><TD CLASS="quote">it should work. 88 trannys have 21 splines and 92 trannys have 20 splines so 89 should be 20 splines im 99% sure</TD></TR></TABLE>
if the spline count doesnt match then the tranny wouldnt fit onto the block correct?
it seemed to have slipped on with no resistance, the car runs, and i can shift thru gears with no problem. i havent taken it for a test drive yet tho. mayb that will actually tell me if it truly worked?
Old Jun 19, 2006 | 09:37 PM
blkrex's Avatar
u r kinda a clown....if the tranny went right on then yah it should work....and juss put it in gear and try 2 push it ...if u dont want 2 drive it hurt anything....
Old Jun 20, 2006 | 06:08 AM
akteamster's Avatar
Default Re: (blkrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkrex &raquo;</TD></TR><TR><TD CLASS="quote">u r kinda a clown....if the tranny went right on then yah it should work....and juss put it in gear and try 2 push it ...if u dont want 2 drive it hurt anything.... </TD></TR></TABLE>
yeah i know i kinda answered my own question. but i would like some reassurance before i take it for a drive.
Old Jun 20, 2006 | 08:26 AM
d16vtecx's Avatar
it morks
i used a 95 clutch on my si trans
Old Jun 20, 2006 | 08:28 AM
CRXBart's Avatar
Default Re: (d16vtecx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16vtecx &raquo;</TD></TR><TR><TD CLASS="quote">it morks
i used a 95 clutch on my si trans</TD></TR></TABLE>
yep me too but only with a dx tranny.
Old Jun 20, 2006 | 09:52 AM
akteamster's Avatar
Default Re: (CRXBart)
i used a 92 cx tranny and so far so good. still waiting to test drive it as soon as i get outta work.
Old Jun 20, 2006 | 10:23 AM
DEIVIONCRX's Avatar
88 trannys are 21 spline, 190mm clutch, 89 are 20 spline 200mm clutch, 90-00 are 20 spline and 220(212 maybe) mm clutch
the only difference i would think betwen Cable and Hydrolic, is the actuall height of the center section of the clutch disk, i know bseries wont engage if you use the wrong one, so just to be shure measure the 2 and compare
Old Jun 20, 2006 | 11:35 AM
silentdork818's Avatar
Default Re: (DEIVIONCRX)
Dont trip itll work...89+ D-series trannies are all 20 spline. Just make sure you used the 92 flywheel along with the clutch.
luvs2spooge
Aug 31, 2007 06:34 AM
JDMracer17
Nov 9, 2005 08:33 PM
SiBuddy00
Jun 21, 2005 07:57 PM
BseriesHatch
Nov 13, 2003 08:27 AM
hondacivic4g
Mar 17, 2002 12:39 AM
