FS: Various Car Audio Equipment/parts, sub, amp, cap, etc (PA) PICK UP ONLY!
Pictures can be found at http://s81.photobucket.com/alb...tereo/
Parts for sale
1 Audiobahn A4004T 4 Channel Amp (50 watts x 4 or 200 watts x 2) - $75 (NO PICS YET)
1 Audiobahn AW151t 15 inch subwoofer + Box $175
1 Q-Logic Box for the 15 inch subwoofer - QLH-2.2515SS (Less then 6 months old, has sub installed)
1 set of Rockford Fosgate Dual Twist 4 Channel RCA's - $25 (NO PICS, purchased same time as subs, best RCAs I ever owned, made my interior sound quality alot better, originally $50)
1 Lighting Audio Distribution Block LITBD3- never opened! - $5 (Originally $13)
1 set of RCAs- $5
1 Street wires Distribution block (fused)- $5 (NO PICS YET)
About 20 feet of 4 gauge wiring - Make an offer
About 30 feet of speaker wire (probaly 12 or 14 gauge)- Make an offer
20 feet of 8 gauge wire - Make an offer (Used for the 4 channel amp)
2 In line fuse holder plus 2 60 amp and 1 40 amp fuses, and a new battery post terminal.- $5
Specs of everything:
1 Audiobahn AW151t 15 inch subwoofer - less then 6 months old
Specs:
* Optimized for Maximum Sound Quality / SPL
* PHAT 2” Foam Surround
* 120 oz. Magnet
* Non-Pressed, Non-Transfer Paper Cone
* KM3 Coated Cone for Low Cone Distortion
* Flame-Designed Cast Flame Basket
* High-Temp 2.5" ASV Voice Coil Former
* Multi-Connect Lug-Lock Terminals
* Mounting Depth: 7 1/8”
* Hole Cutout: 14”
* Outer Diameter: 15 1/2”
* Size: 15 inch
* Rec. Sealed Box Dims: 1.25 - 3.25 cu.ft.
* Rec. Ported Box Dims: 1.65 - 3.7 cu.ft
* Free Air Usage: not recommended
* Sensitivity: 94 dB
* Frequency Response: 22-700 Hz
* Recommended RMS Power: 650W
* Peak Power Handling: 1300W
* Impedance: 4 ohms subwoofer wiring options
Details:
» Type 2 hatchback style enclosure for one 15" subwoofer
» 5/8" medium density fiberboard construction with gray carpet covering — additional 3/4" front panel supports woofer
» nickel-plated, spring-post speaker terminals
» optional interchangeable baffles accommodate non-round subwoofers
» QXs mounting ring
» internal volume: 2.25 cubic feet
» dimensions: 26-1/2"W x 17-1/2"H x 17"D1 x 12"D2
Description:
Lighting Audio Bolt Series features solid machined brass construction with hard gold plating for reliable connectivity. The BD3 is ideal for connecting amplifiers and fused distribution blocks. It feature a clear base and snap-off cover with etched logo. The BD3 accepts two 0/1 gauge inputs and three 4 gauge outputs.
The sub and box were purchased in February, and used til about mid april. I am buying a new car and want to keep the sound system stock. The sub and box are in excellent condition, and everything works as described (sounds good too). Email me with any questions. If I have anything else laying around I think you could use I will add that into it as well.
Asking $450, cash on PICKUP for EVERYTHING, no shipping!
1 Audiobahn A8002T Amplifier -$ 100 SOLD
1 Audiobahn capacitor - $45 SOLD
You can email me, or call me at 484-716-5802.
Modified by Nors at 12:30 PM 6/20/2006
Modified by Nors at 12:31 PM 6/20/2006
Parts for sale
1 set of RCAs- $5
Specs:
* 120 oz. Magnet
* Hole Cutout: 14”
* Size: 15 inch
Details:
» QXs mounting ring
Description:
superthug
Apr 3, 2008 04:39 PM
b16rex_02
Apr 7, 2007 10:39 PM
Nors
Jun 20, 2006 11:33 AM
md88hfcrx
Mar 17, 2006 05:31 AM
