Oil recommendation
Old Jun 19, 2006 | 10:52 AM
ZXRider's Avatar
Default Oil recommendation
I have a 1998 Prelude with high miles...about 158K and was wondering what kind of oil you guys recomend? brand and rating of the oil. Also im new to this car and would like to know how many qts does it take. Thank you.
Old Jun 19, 2006 | 10:56 AM
DIRTYsouthBB6's Avatar
Default Re: Oil recommendation (ZXRider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZXRider &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1998 Prelude with high miles...about 158K and was wondering what kind of oil you guys recomend? brand and rating of the oil. Also im new to this car and would like to know how many qts does it take. Thank you.
We get about 23,345,345 of this question every day... the red button on the top right-hand corner of the screen will lead you to a thread that has your answer.
Old Jun 19, 2006 | 11:06 AM
ZXRider's Avatar
Default Re: Oil recommendation (DIRTYsouthBB6)
doi...sorry completely slipped my mind that this forum might have a search function. I'm a member of TwinTurbo.net (used to own a 300ZX) and people always rip on the new guys who don't search.....don't know what came over me =P Thanks.
Old Jun 19, 2006 | 12:00 PM
98vtec's Avatar
moderator emeritus
you can run a synthetic blend. Dont know if i would run a full synthetic oil in there since its so thin and your seals may be worn out and will leak the oil.
owners manual says to run 5w30 synthetic. You can run 10w30 for high mileage to help reduce oil consumption and help your seals from leaking since its a thicker oil.
i run Mobil1 extended performance 5w30, but my motor only has 45k on it.
Old Jun 19, 2006 | 12:07 PM
mkazm83's Avatar
Default Re: Oil recommendation (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">you can run a synthetic blend. Dont know if i would run a full synthetic oil in there since its so thin and your seals may be worn out and will leak the oil.
i run Mobil1 extended performance 5w30, but my motor only has 45k on it.</TD></TR></TABLE>
Why did you stop using RP?
Old Jun 19, 2006 | 12:09 PM
98vtec's Avatar
moderator emeritus
Default Re: Oil recommendation (mkazm83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkazm83 &raquo;</TD></TR><TR><TD CLASS="quote">Why did you stop using RP?</TD></TR></TABLE>
i still use it. Just depends on how my wallet feels the day i go buy oil
Old Jun 19, 2006 | 12:31 PM
95PreludeSi's Avatar
I would say unless you are going to track the car and see high oil temps conventional 5w-30 or 10w-30 would be fine. Also it should take around 5qts. Also, since you have a H22a it is normal for you to burn a qt or more between changes. Check your oil often
Old Jun 19, 2006 | 12:37 PM
jardolei's Avatar
Total Oil = 5.1 L
I just changed to Mobile1 5w30 100% synthetic
And yes check your oil often
Old Jun 19, 2006 | 01:39 PM
ninja 6's Avatar
Default Re: Oil recommendation (jardolei)
my 2.3 used to leak a bit...and I ran 10W30 high mileage for about a year and a half. Miraculously I have not yet had any leaks since then. I started using some synthetic blend but it wasn't really worth the cost, imo, for an h23a1. So i stick with regular mobil1 10w30 standard oil, no leaks, no oil burnoff.
Old Jun 19, 2006 | 02:07 PM
tcontesh's Avatar
now I know that everyone has thier opinions and there are a million different oil companys out there, but with those kind of miles youre best bet might even be a 20w50 oil. I switched over to royal purple 20w50 from mobil 1 5w30 and my car stopped burning oil and leaking oil.
Old Jun 19, 2006 | 04:26 PM
AsiAnVenOm's Avatar
That's cuz your car is boosted...put that on an NA h22a and you be crawling...
Edit: going from 5w30 to even 10w30 and you can already feel the different...
Old Jun 19, 2006 | 04:39 PM
tcontesh's Avatar
Default Re: (AsiAnVenOm)
I started using the royal purple before the turbo kit and the car stopped burning oil and leaking it. when our cars have high miles and it is burning oil it is recommended that you use a heavier weight.
and like i stated before everyone has thier own opinions i was just giving my 02 cents
Old Jun 19, 2006 | 07:07 PM
Under most engine operating conditions, a 10W-30 will not be any thicker than a 5W-30... oils with dual viscosity ratings adapt to temperature settings
Old Jun 19, 2006 | 09:46 PM
ejprimo's Avatar
i would suggest you go to walmart and pick up some phillips 66 trop artic synthetic blend 10w-30 for $1.50 a quart. absolute best bang for buck motor oil!
Old Jun 20, 2006 | 12:02 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AsiAnVenOm &raquo;</TD></TR><TR><TD CLASS="quote">That's cuz your car is boosted...put that on an NA h22a and you be crawling...
Edit: going from 5w30 to even 10w30 and you can already feel the different...</TD></TR></TABLE>
you're not feeling any difference. they're the same viscosity when the engine is warm.
that's what the "30" in Xw30 means. The only difference is that the 10 is thicker when the engine is cold.
Old Jun 20, 2006 | 08:21 AM
vinuneuro's Avatar
Default Re:
10w30 is typically only thicker at start-up, which makes no sense to use it. If you look at the spec sheet for SuperSyn 5w30 v. 10w30, the 5w30 actually has a marginally higher viscosity well past 100*C, and has a higher flashpoint point as well. Relative viscosities don't matter as much these days with modern additive packages in synthetic oils.
Old Jun 20, 2006 | 08:23 AM
98vtec's Avatar
moderator emeritus
learn something new everyday
Old Jun 20, 2006 | 08:24 AM
vinuneuro's Avatar
Default Re: Oil recommendation (tcontesh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tcontesh &raquo;</TD></TR><TR><TD CLASS="quote">now I know that everyone has thier opinions and there are a million different oil companys out there, but with those kind of miles youre best bet might even be a 20w50 oil. I switched over to royal purple 20w50 from mobil 1 5w30 and my car stopped burning oil and leaking oil. </TD></TR></TABLE>
That's because the oil is so friggin thick. This it too thick for your engine. There's no reason to go past a 30wt (40wt max). You're losing effciency, making your engine pump that thick of an oil, not to mention loss in oil pressure.
Old Jun 20, 2006 | 08:26 AM
donnaspl's Avatar
is anyone here?
Old Jun 20, 2006 | 08:27 AM
98vtec's Avatar
moderator emeritus
Default Re: (donnaspl)
wtf are you talking about.
Old Jun 20, 2006 | 10:58 AM
JDMF22B's Avatar
Default Re: (98vtec)
Royal Purple for the win. Even though it killed my engine ;p
Old Jun 20, 2006 | 11:05 AM
K-Spec's Avatar
Default Re: (JDMF22B)
how'd it kill your engine?
Old Jun 20, 2006 | 05:25 PM
tcontesh's Avatar
Default Re: Re: (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">
That's because the oil is so friggin thick. This it too thick for your engine. There's no reason to go past a 30wt (40wt max). You're losing effciency, making your engine pump that thick of an oil, not to mention loss in oil pressure.</TD></TR></TABLE>
with the turbo heating up as much as it does i wouldnt want it any thinner
Old Jun 20, 2006 | 07:24 PM
vinuneuro's Avatar
Default Re: Re: (tcontesh)
...you realize it's not going to flow that well right? Look up the oil specs for any oem turbocharged vehicle, you're not going to find anything heavier than 5w30.
bigstevo106
Apr 25, 2006 06:00 PM
illagee
Nov 6, 2005 05:21 PM
whitelightning
Sep 26, 2003 01:35 PM
makaveli284
Jun 9, 2003 10:45 AM
