Everything you need for a mini-me: D16Z6 head, timing belt, dizzy, P28 ECU, sparkplugs/wires, and mo
I recently bought everything necessary for a mini-me, but because of a bad bottom end D15 block, I had shitty compression numbers and honestly I am too busy and frustrated to deal with it. Up for grabs are the following, shipped:
D16Z6 cylinder head - $140
includes: vtec solenoid, vtec oil pressure plug, painted valve cover with new gasket
D16Z6 distributor - $70 (coil was checked, it's good)
D16Z6 timing belt and tensioner - $30
P28 ECU for A/T - $110
New D16Z6 9mm spark plug wires - $20
New D16Z6 NGK platinum spark plugs - $15
New D15B7 water pump - $20
New D16Z6 exhaust mani gasket - $15 (I used the one that came with my header)
All of the above together for $400
Also, I have:
New ebay intake - $25
New ebay header - $50 (fit perfectly on 95 dx)
D series O2 sensor if yours is stuck - $10
D15B7 P06 ECU for A/T - $30 sold
Modified by ZeeSix at 7:07 AM 6/24/2006
Modified by ZeeSix at 5:17 PM 7/2/2006
Modified by ZeeSix at 6:43 AM 8/3/2006
Also, I have:
EVIL EF9 RHD
Jan 16, 2013 08:49 PM
