crack in manifold
Old Jun 19, 2006 | 08:01 AM
thirty2brdr's Avatar
Default crack in manifold
yeah i have a crack in my exhuast manifold.blah i hate cast iron but i just put some jb weld on there for temporary issues until i can afford to buy a new one. stainless steel this time.
i was just wondering how long i should let it sit and set in to the crack before i can boost it again. its only tuned to 6psi. 95 integra se thanks
Old Jun 19, 2006 | 05:03 PM
y7turbo's Avatar
Default Re: crack in manifold (thirty2brdr)
wait, you really put jb weld on an exhaust manifold?
wow!
Old Jun 19, 2006 | 07:10 PM
EnzoSpeed's Avatar
Default Re: crack in manifold (y7turbo)
What's he supposed to do? JB won't hold, but neither would a weld. Cracked cast iron is a losing situation.
Old Jun 20, 2006 | 05:13 PM
y7turbo's Avatar
Default Re: crack in manifold (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">What's he supposed to do? JB won't hold, but neither would a weld. Cracked cast iron is a losing situation.</TD></TR></TABLE>
whats are you talking about?
welding cast iron isnt as hard as everyone makes it to be. i welded my old hf mani with my mig welder and it held up just fine and never cracked again. i ended up selling the mani and it still hasnt cracked in a year the other guy has had it..
putting jb weld on an exhaust mani, yeah thats a great idea.
wonder if there is a Honda tech Dumbass of the year award, this sure would rank high up there.
post a picture of your jb welded manifold, i would love to see it!
Old Jun 20, 2006 | 08:16 PM
B18C1CYA's Avatar
do not put JB weld on it , have it tig welded with a high nickel rod , also drill a small hole at each end of the crack to stop it from spreading , and then heat up the manifold with a torch and get it nice and hot , and then weld it up and let it cool down on its owen , dont run it under water just leave it be , should fix it for you.
Old Jun 21, 2006 | 02:53 AM
2point2's Avatar
Default Re: crack in manifold (B18C1CYA)
^^that's great advice.
http://jbweld.net/products/jbweld.php
read the bottom right corner in bolt italics.
"Not recommended for use on manifolds, exhaust systems, and other engine components which normally operate at temperatures above 500° F."
for that to be the only warning on that page suggests that it's a really dumb idea to use it on exhaust manifold.
Old Jun 21, 2006 | 02:20 PM
beepy's Avatar
Default Re: crack in manifold (2point2)
Wow. Probably the only thing on a car that you CAN'T use JBWeld for is the exhaust.
But live and learn. There has to be a reason that companies need to put "do not eat" warnings on rat poison and "caution: Hot" on hot coffee.
Old Jun 21, 2006 | 06:47 PM
ManBearPig4silly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">do not put JB weld on it , have it tig welded with a high nickel rod , also drill a small hole at each end of the crack to stop it from spreading , and then heat up the manifold with a torch and get it nice and hot , and then weld it up and let it cool down on its owen , dont run it under water just leave it be , should fix it for you. </TD></TR></TABLE>
You can also slow down the cooling process by burying it in sand. I just welded up a volvo t3 turbo to use a standard t3 flange. After I got done preheating it and welding the half moons shut I placed it in a preheated oven, shut the heat off, closed the door (I threatened death upon anyone who opened it )and let it cool down overnight. Came out pretty sweet
sorry no pics. I already flattened it all out.
PS burying a fully assembled turbo in sand probably isn't a good idea I recommend the oven method.
BlakeJ53
Jan 24, 2008 06:16 AM
ajusaf
May 5, 2005 01:49 PM
gtowni3
Dec 15, 2004 06:06 PM
boostedcivichatchbacksi
Apr 9, 2004 07:44 PM
91hatchcivic
May 21, 2003 08:34 AM
