Erractic Idle with 90 model accord
When I start up my 1990 Accord Coupe it goes to 3000 RPM's and down to 1000 RPM's and then back to 3000 RPM's and it just does this over and over,so if you could help me with this proble that would be great.Thanks
IACV. Take it off, clean it, try it again. Problem contuniues, check the TPS. Those 2 sensors are what controls idle. Check aswell for any vacuum leaks. If you have a cracked/unplugged vacuum hose the idle will jump like crazy. A easy culprit for the F22 is the top mounted PCV valve gets bumped and it cracks, loosing any kind of vacuum seal. Happened to a friend with a 90 Accord Sedan.
SlackerAccord
Sep 22, 2005 08:49 PM
