A couple of little problems
Old Jun 19, 2006 | 12:29 AM
eagleclawracing's Avatar
Default A couple of little problems
Well here they go today i tried to install my Pioneer indash Tv With Xbox.....that didnt work becuse the screen Didnt want to turn on...then when i went to drive home the Tach (Stock) started jumping around then stoped workin. every time i turn the car off it goes up then goes back down to 0.. So what can cause this problem i thought it was my iNdaglow but Tach moves freely around and goes all the way to red line then back to 0....So i got all pissed off and took off really fast around a corner then my axel broke right at the cv joint..So would the axels of the ex honda accord be the same as my lx? both cars are 5 speed 94 ...Then my both my hids went out but when i put the factory bulbs they work......... Then my Volt meter reades at 12.3 idling then 14 rollin....I have optima Red top batt. and got my alt check out they said it was fine.. WOuld the low voltage be caused of my pulley kit?.......I am just having a bad today with my car its 330Am and i have been workin on it since 10in the morining and all that stuff happend today...Im sorry if post sounds a little stupied its just really lait i tried searchin but no help
Old Jun 19, 2006 | 04:09 AM
globeDELETETHIS USER's Avatar
Both CV Shafts are the same on each car...
Did you Hook up the wires on the indash correctly?
Id need to see a wiring diagram of the Indash Wires and a diagram of your cars stock radio harness ( the wires )
and ill tell you exactly which wires go where
Old Jun 20, 2006 | 06:21 AM
Default Re: (NewJerseyhonda)
The indash i bought didnt come with any digarams like i can get the brain to come on but cant get the screen to power up
melancollie
Mar 2, 2012 10:35 PM
Megaseth
Sep 11, 2006 02:00 PM
GReddy212
Feb 2, 2006 07:29 AM
vtec_crazy
Mar 3, 2005 12:55 PM
imsavant
Dec 3, 2003 01:01 PM
