2 questions!!
Old Jun 18, 2006 | 09:33 PM
EFwithS2000taillights's Avatar
Default 2 questions!!
Ok 1st question....How can i wire up a 92-95 dist. to my dx to si converted wiring harness??
2nd question...What else hooks up to the vtec solenoid, it looks like a hole for a oil pressure guage...wierd
by the way, I am doing a d15 vtec swap into my 89 civic dx...thanx
Old Jun 19, 2006 | 03:35 AM
ham's Avatar
ham
Default Re: 2 questions!! (EFwithS2000taillights)
question 1: You can only use that distributor if you convert to obd1. if you are staying obd0, you need to hack an Si distributor. I recommend doing the obd1 converstion.
question 2: Only 1 wire goes to the vtec solenoid. Maybe you are looking at something else? Post a pic if necessary.
Old Jun 19, 2006 | 07:36 AM
does the dist have to be si??
Old Jun 19, 2006 | 07:48 AM
nappyroots827's Avatar
Default Re: (EFwithS2000taillights)
si or civic ex, any EF that came with multi port fuel injection, except i don't think the HF dizzy works, could be wrong tho
Old Jun 19, 2006 | 11:17 AM
jlicrx's Avatar
Default Re: (nappyroots827)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">si or civic ex, any EF that came with multi port fuel injection, except i don't think the HF dizzy works, could be wrong tho</TD></TR></TABLE>
HF uses same distributor as Si
doc1911
12
Sep 24, 2008 02:12 PM
VtecKiDD
Sep 21, 2006 11:49 AM
tete787
Oct 30, 2005 05:52 PM
the jdmchop
Dec 28, 2003 12:38 PM
Lo-Buck EF
Jun 3, 2003 10:24 AM
