Squeaking at idle? Belts?
Argh.. this has been a consistent problem.. more like a major annoyance for me for the past few months. At idle, and as I increase the RPM, a high pitched squeal emits from the drivebelt area under the hood. I've checked it out, and it is almost certainly coming from the crank pulley. What can I do to fix this? Like I said, it doesn't seem to be coming from any of the accessories, but from the crank pulley itself. Thanks.
i got the same squeak too but its coming from my alternator belt.
if i spray lithium silicone grease on it. it goes away for a few days but it comes back.
could this be that i need to tighten my belt tensioner?
[Modified by 95BlackGS-R, 9:24 AM 4/17/2002]
Mine is just starting to do this as well, anyone have tips?
Also, is their any sort of wear indicator on your timing belt? Or do shops put a sticker somewhere under the hood when they replace the belt saying the mileage?
i am yet another person with this prob.. i am going to try and check the deflection on the belts and let you guys know if that does it. i also tried some belt dressing, but that just got that side of the engine bay dirty and greasy as hell
From what I understand when you have a squealing noise coming from one of your belts most of the time it is loose. I would first check the alternator belt since that is the culprit most of the time.
I have a kind of squeeking noise when my engine is cold, I think the alternator bearings may be going out... either that or the belt is too tight I think.
