How will my car idle with 370 cc injectors with stock ecu?
Old Apr 16, 2002 | 08:16 PM
Ri5e's Avatar
Default How will my car idle with 370 cc injectors with stock ecu?
As most of you should know, my car got jacked and the theives took my S-AFC. The car is currently at the dealership getting fixed up from the damages (Busted ignition, Fuel lines, etc...)
I never had a change to run the S-AFC at 0% on the 370ccs so I don't know how the car will idle/run with the 370's.
So basically my stock ECU will be controlling the injectors. I dont' have the stock 240cc's anymore. How will my car idle/run? Like Crap?
Old Apr 16, 2002 | 08:23 PM
MiraiZ's Avatar
Default Re: How will my car idle with 370 cc injectors with stock ecu? (BG Boost)
Like crap....I will be suprised if you can keep it running. I tried starting my car after going from 308cc to 450cc and it sounded like a lawn mower. You have to adjust it down...
Old Apr 16, 2002 | 08:28 PM
Ri5e's Avatar
Default Re: How will my car idle with 370 cc injectors with stock ecu? (MiraiZ)
450 cc is huge. Lets talk about 370 ccs
Anyone have their stock injectors for sale? help...
Old Apr 16, 2002 | 08:35 PM
b16ahybrid's Avatar
Sure,I have a set of 4 240cc injectors from my sir2.Let me know if your interested.
Old Apr 16, 2002 | 08:36 PM
shamoo's Avatar
Will you make something up for me please?
Mine started when I had 370's for a while. But it died about 5 seconds later. I had to plug the AFC back in to start it back up.
I guess once you get it started, you can keep gassing it or something.
EDIT: Corrected my sentence....typed 310's, but meant 370's.
[Modified by shamoo, 12:57 AM 4/17/2002]
Old Apr 16, 2002 | 08:37 PM
MiraiZ's Avatar
450-370...not a major diffence when compared to the the stock ones...I have stock JDM 308cc's but it'll probably be a while before they arrive there.
Old Apr 17, 2002 | 06:58 AM
1fstevo's Avatar
New User
hey, I just started my car with 720cc injectors using stock ecu. Pretty ugly idle but it idles surprisingly. It dies after about 10 minutes.
Old Apr 17, 2002 | 07:49 AM
GSRwBOOST's Avatar
Default Re: How will my car idle with 370 cc injectors with stock ecu? ([Evo]Hybrid)
I have 370's tuned down with the fields set at -30% for 1-3,000 rpm ranges.
The car still has a little bouncy idle and sometimes idles at 1000 for a minute or two at a stop light, then drops to 800 or so.. and feels like it's "missing" due to all the fuel buildup.. occasionally i get the rich/lean code too... and that's frustrating as hell sometimes.. but oh well.. the price for performance...
its tolerable, but not sure for how long..
Old Apr 17, 2002 | 07:50 AM
TurboR's Avatar
New User
I have Rc 370s's 4 sale. Let me know if u intrested. Fynejatt21@aol.com
Old Apr 17, 2002 | 09:56 AM
sgT's Avatar
sgT
Default Re: How will my car idle with 370 cc injectors with stock ecu? (shamoo)
Keep in mind that if you unplug the AFC and do not reconnect the map signal
then the car will not run well regardless of the injectors you have in it.
Old Apr 17, 2002 | 12:13 PM
lucas569's Avatar
i do, just took em out the other day, how much you offering? email or im me. btw youlive in VA right, if i send them out tommorow they would prolly be there by sat
[Modified by lucas569, 1:15 PM 4/17/2002]
Old Apr 17, 2002 | 01:12 PM
shamoo's Avatar
Default Re: How will my car idle with 370 cc injectors with stock ecu? (sgT)
This is true.....when my AFC was crapping out, I had a paper clip in the map signal slot in the harness.
01typerboi
Dec 23, 2010 12:42 PM
SFC
Jun 21, 2004 10:32 AM
egturbo
Jul 14, 2003 12:21 AM
red civic standard
Nov 15, 2002 02:06 PM
internet ay
Aug 10, 2002 09:01 PM
