Hi.. Need help w/ axle & rotor change.
I'm new and I just have a few quick questions on changing the cv axle.
1) Will I need to replace or buy new cotter pins?
2) Any tips or ideas to removing the lower ball joint? Should I just get a pitman puller? If so what make and any particular model?
3) I can't seem to find the DIY for this one. Someone told me there was one, but I dont' know where it is.
Well, i would replace the cotter pins, but if you can reuse the old ones than i guess it would be fine.
When i did my CV shafts i dont remember disconnecting the ball joint, i just took off the hub and everything, and the shaft basically slid right out
But I guess maybe your car may be differnt
1. You should always replace your cotter pins. Cost like 2 dollars and gives piece of mind.
2. I personally just banged the LCA a couple of times with a hammer and it popped right out. A puller facilitates things, but really isn't necessary.
$2 dollars for a cotter pin
?!?!?!?!?! i hope you mean a pack of like 50 of them! haha
edit: where can i buy cotter pins at? i been needing to replace mines, they are so twisted up its a bitch to get them out and in.
?!?!?!?!?! i hope you mean a pack of like 50 of them! hahaedit: where can i buy cotter pins at? i been needing to replace mines, they are so twisted up its a bitch to get them out and in.
I know the small stuffs doesn't hurt to replace, but just thought I'd ask.
Thanks to all
BTW, anybody got the DIY? STill unsure ove the LBJ and what not, but I guess I have to see it b4 I really know what I gotta do.
Thanks to all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 »</TD></TR><TR><TD CLASS="quote">$2 dollars for a cotter pin
edit: where can i buy cotter pins at? i been needing to replace mines, they are so twisted up its a bitch to get them out and in.</TD></TR></TABLE>
No, lol. Not 2$ each.
You should be able to buy them at your local car parts store. If not check some place like Home Depot.
?!?!?!?!?! i hope you mean a pack of like 50 of them! hahaedit: where can i buy cotter pins at? i been needing to replace mines, they are so twisted up its a bitch to get them out and in.</TD></TR></TABLE>
MysticSpade
Mar 11, 2004 02:22 PM
ArchAngel Sabastian
Aug 21, 2002 08:20 AM
