h22 swap help in 4th. gen.
ok, so I am still in the middle of my h22 swap, and this plug is bugging the hell out of me, I can not get it reach the plug on the motor. now I have not changed out the wiring harness and I can figure this out.
so I was looking at the back of my f22 block, and there isnt a plug where it will plug up, and I dont even know what it goes to. it is connect to a hard line that looks like it goes to the hi pressure line of the p/s pump...
this plug
goes here about the oil filter on my h22 block...
and then here here is a pic my f22 block, no plug above the oil filter...
HELP!!!
and here is a pic of them together, you can see I have a good 4-5 inches to go...
sorry for the crappy pics, all I had was my phone to take the pics.
this plug
HELP!!!
on my jdm swap i just did the harness reached the green plug in the first pic.
The second plug right under the IM is the Knock sensor i believe.Your trying to connect two plugs that dont connect.They should both be on the H22 harness and you should be able to tell very easily which plug goes were b/c the one that goes to the knock sensor is short .
is that what the plug is above my oil filter on my f22 block?? I have no need for the knock sensor, im not ever wiring it up. AND what is the plug on the hard line for? looks as tho it goes to power steering...
The plug above the filter on the F22 is the oil pressure sending unit.
Knock sensor on the H
The other green switch is the ps pressure switch for the Variable Assist Power Steering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 »</TD></TR><TR><TD CLASS="quote">The plug above the filter on the F22 is the oil pressure sending unit.
The other green switch is the ps pressure switch for the Variable Assist Power Steering.</TD></TR></TABLE>
is the oil pressure sending unit on the h22 below the oil filter?
thanks for everything else!
