swaping B18a into crx/civics
no you cant use the integra mounts, its not plug and play, and yea engine bay wise the sedans and crx should be the same. the wagon on the other hand probably not
there are alot of choices.
ebay= not recomended
avid racing
enjo= i personal dont like ths design(same design as ebay)
arizona race
hasport
but it is a plug and play situation as stated above
avid racing
arizona race
hasport
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow rex »</TD></TR><TR><TD CLASS="quote">i was thinkin of buying that kit but wassnt sure about it. has anyone used it before</TD></TR></TABLE>
Ive used thme when swapping in others cars...They're ugly but very good mounts.....Not really sure how the customer service is though,,never had a mount break yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">good mount kit for $100 http://streetimports.com/
What do you have,,si,dx,hf? </TD></TR></TABLE>
well i dont have a civic yet... i have a complete 91 integra with front end damage... will be swaping it to either a 4dr or hatch...
plug in play as in integra headers bolting up to oem civic cat...?
can i bolt integra rear muffler on the oem civic mid pipe??
hasport mounts are your best bet. i hear that some cheaper mounts may give u a problem with the engine rubbing on the hood. but i guess it all depends what car ur putting it in. i was gonna drop a LS into my crx. but im not sure.
I'm using arizona race mounts and shift linkage they are a solid product, as for the headers, mine didn't line up there was a gap but if you use the integra cat it might work, I think it was a little longer (B18b w/ DA headers to homemade testpipe to Thermal R&D)
There are a lot of little things but if you have a donar car you should have most, check the FAQ link at the top it will tell you everything you need
yes and alot will depend on which car and model you get...also whether the motor is obdo or obd1...but like said above you will have a lot of what you need from that teg...
hondatuner20
Jan 6, 2006 05:58 PM
russian_racer
Sep 19, 2002 08:53 PM
