injector swapping
Old Jun 18, 2006 | 11:57 AM
bigwill_2004's Avatar
Default injector swapping
i have an 88 crx hf with a d16a6 swap (si). what injectors can i swap from another honda that would give me a boost in hp?, what will bolt in and give me more fuel?? ive tried finding it on HT but couldnt find this question...thx
Old Jun 18, 2006 | 12:00 PM
SVOboy's Avatar
Injectors won't give you more power. In fact, injectors of different sizes will seriously expletive up your performance. You should be using 240cc injectors that came with the d16a6 unless you want to eliminate the resistor box and use obd1 240cc injectors.
Old Jun 18, 2006 | 12:03 PM
Default Re: (SVOboy)
so there is no way i can put in a prelude or accord injector and it wont give me more fuel and increase hp? im tryin to find some easy ways to gain hp i have an integra parts car, engine is apart. its a b18a1, anything i can get off of there and put on this one to make it better?
Old Jun 18, 2006 | 12:06 PM
SVOboy's Avatar
You might be able to physically put the injector in, but more fuel will not magically increase horsepower. It will, if anything, make the car run like ****, and if you put the h22 345s in your car will prolly be spitting gas out the tailpipe.
Old Jun 18, 2006 | 12:08 PM
lol, dang, appreciate it man, i got some stuff comin for it, just tryin to find a few extra things i could maybe to do it, i have ordered a stage 3 and lightweight flywheel, it has a bomz high flow intake and a 4-2-1 header, its a si engine in a stripped hf, u have any other suggestions i could do to it? last question i promise...
Old Jun 18, 2006 | 12:13 PM
SVOboy's Avatar
Shoot, turbo is the best/easiest way to make power, just make sure you get the d16a6 injectors because I think if you're using the hf injectors they might be smaller.
Old Jun 18, 2006 | 12:15 PM
290allen's Avatar
Default Re: (bigwill_2004)
swap on the throttle body from the b18a1, you wont per say gain any horsepower but you will feel a faster throttle response.
Old Jun 18, 2006 | 12:17 PM
Default Re: (290allen)
i tried to swap it but the 4th stud hole on the throttle body dont fit my intake
Old Jun 18, 2006 | 01:12 PM
slpnz6's Avatar
your using the a6 manifold? i used the z6 manifold with the teg throttle body..
Old Jun 18, 2006 | 01:13 PM
SVOboy's Avatar
Mehbe I get a teg tb to put on my z6 im, hmmm.
Old Jun 18, 2006 | 01:21 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Shoot, turbo is the best/easiest way to make power, just make sure you get the d16a6 injectors because I think if you're using the hf injectors they might be smaller.</TD></TR></TABLE> A different cam maybe, but a turbo makes the world go round.
MastaFlyMason
Sep 3, 2017 10:06 AM
phearable
Mar 22, 2008 08:26 PM
mtber
Jul 20, 2007 09:49 PM
