pg7 ecu in 91 crx dx
Old Jun 18, 2006 | 11:49 AM
stemiched's Avatar
Default pg7 ecu in 91 crx dx
alright so i just got a pg7 ecu and i put it in my 91 crx dx and it only reves to about 3 and a quarter, does the ecu need chipped or what can i do? my motor is a d16a6 but has the 2 point timed fuel injection. i dont know anything about the motor other than it has 2 point timed fuel injection and the block seas d16a6
Old Jun 18, 2006 | 11:55 AM
dr_latino999's Avatar
Default Re: pg7 ecu in 91 crx dx (stemiched)
As long as you are using DPFI you must use the DPFI computer. If you use another computer, youre injectors will not be firing right, and the distributor will be sending "incorrect" signals leaving your ECU in limp mode.
Old Jun 18, 2006 | 12:04 PM
SVOboy's Avatar
Everything he said.
Old Jun 18, 2006 | 12:19 PM
stemiched's Avatar
Default Re: (SVOboy)
so nothing i can do to use this ecu? cant be chipped or anything? how hard is it to swap the fuel injectors? i have an 88 parts car the have the 4 point fule injectors
Old Jun 18, 2006 | 12:29 PM
SVOboy's Avatar
The MPFI swap isn't that hard.
You can chip the pm5, but why? There's nothing to do with it.
Old Jun 18, 2006 | 12:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">You can chip the pm5, but why? There's nothing to do with it.</TD></TR></TABLE> Actually, the DPFI computer lacks the injector circuitry for 4 injectors so you can't chip it.
Old Jun 18, 2006 | 12:38 PM
SVOboy's Avatar
Actually, I chipped my pm5 before I did my mpfi swap.
I basically ended up using a stock chip, because I couldn't figure out the fuel maps since they're messed up due to the DPFI, but it was done.
Old Jun 18, 2006 | 12:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Actually, I chipped my pm5 before I did my mpfi swap.
I basically ended up using a stock chip, because I couldn't figure out the fuel maps since they're messed up due to the DPFI, but it was done.</TD></TR></TABLE> Ok, so you chipped but the circuitry itself can't support MPFI , or so I was told.
Old Jun 18, 2006 | 12:40 PM
SVOboy's Avatar
Yeah, it cannot support MPFI, I just chipped it to try and mess with the DPFI timing a bit, which was basically worthless in the end.
gunwoo82
Sep 21, 2005 04:07 PM
Lightning Lover.
Nov 18, 2003 12:27 PM
R_yd
11
Nov 9, 2002 11:19 PM
hondacivic4g
Jan 10, 2002 05:46 PM
