cable LS tranny not disengaging
clutch not disengaging. we replaced the through-out bearing and installed a new pilot bearing and torqued the pressure plate down as specs require (to 19 lb-ft) put the tranny back in ,adjusted the clutch cable so the lever was tight and the clutch doesn't do anything. it will start and run fine, but cannot shift once it is on, and if it is started while in gear the wheels will spin and everything but will continue to spin at the same speed when i put in the clutch. anyone ever seen this happen before thanks!
Modified by honda_boy_1990 at 6:49 PM 6/23/2006
speedfreek128
10
Mar 28, 2008 07:45 PM
aaronhume
Jun 23, 2006 05:46 PM
