How do I calculate the stroke from the rod length
Old Jun 18, 2006 | 01:32 AM
totalimpact's Avatar
Default How do I calculate the stroke from the rod length
How do I calculate the new stroke when going from the stock LS rod of 5.394" to a longer 5.967" rod? In mm that is 137.0076 mm up to 151.5618 mm.
I am guessing I would be going from a 89 mm stroke to a 95 mm stroke?
I am trying to figure out what my compression will be on this thing - https://honda-tech.com/zerothread?id=1660368 - any compression geeks feel free to jump up!
I am trying to use the c-speed calculator.
Thanks a bunch
Old Jun 18, 2006 | 08:08 AM
Chiovnidca's Avatar
Default Re: How do I calculate the stroke from the rod length (totalimpact)
Using a longer rod wont change the stroke, that's determined by the crank throw. A longer rod will raise the piston height, making more compression.
Old Jun 18, 2006 | 10:20 AM
Default Re: How do I calculate the stroke from the rod length (Chiovnidca)
ya- I knew that, was just being an idiot and forgetting what i knew.
I guess what I really need to figure out is the piston to deck height -
The stock height should be .020".
The new rods are .573" longer.
I am adding .75" to the deck - so I should have:
.75-.573=.177 of additional clearance - right???
add that to the stock clearance already there .177+.020=.197 of total piston to deck height - right???
This doesnt work right, that sounds like to much clearance and lowers the compression too much according to the c-speed calculator.
I figured this out using specs for B20 block - since Im using a B18 crank and 84 mm pistons, my arias pistons have a -12cc dome displacement, GSR head, .197" deck height and everything else should be standard - this gives me 6.7:1 compression and 2 liters of displacement.
Some expert insert accurate knowledge here please.
Old Jun 19, 2006 | 09:43 AM
anyone???
Chugger
Nov 19, 2013 05:33 PM
Rocket
296
Jan 17, 2011 01:21 PM
boostin b16
Dec 29, 2003 11:04 AM
10K2HVN
Mar 17, 2003 11:16 AM
Spade
Nov 8, 2001 08:15 PM
