Body work Question 90 Accord Dx, Rear fender rust (u know where)
Old Jun 17, 2006 | 05:51 PM
globeDELETETHIS USER's Avatar
Default Body work Question 90 Accord Dx, Rear fender rust (u know where)
ok well i have a Hole from some rust in my rear fender, you guys know where
So what i did was cut a big square out of the fender where the rust was, and then i traced some cardboard, around the square i cut out, and i traced it onto a piece of 22 gauge sheet metal, i cut it out
Now should i just weld it in place or what?
There seems to be a contour where the hole is, how can i go about fixing the sheetmetal so it matches the rest of the fender
Or should i just weld the piece in then form the metal that way.. then bondo it?
Im not Looking For perfection, i just dont want it to be a huge rust hole there anymore..
Old Jun 17, 2006 | 09:49 PM
londonsupra's Avatar
Default Re: Body work Question 90 Accord Dx, Rear fender rust (NewJerseyhonda)
um since no one replyed i will try and lend some advice.
You want to weld the new metal in but make sure to tac one side then go to the other
side as not to get the metal too hot as it will warp you probally know this already
though.
Proper shops use a tool called a break i think.. it helps them form the metal.. but since
your not after perfection tacing it in sould be fine.. you can probally get by using a body
work hammer then once the metal is formed good enough spead the bondo thin and l
long around the contour of the curve.. use a large wood block with sand paper and
sand it down to ensure its smooth. Then make sure to use a zinc based primer so it
doesnt rust again.
hoped this helped a little.
Old Jun 17, 2006 | 10:49 PM
Leo C's Avatar
Night Owl
weld it into place then smooth the welds then do the bondo and primer..
Old Aug 7, 2006 | 09:23 AM
vestalfootball72
Guest
Posts: n/a
Default Re: Body work Question 90 Accord Dx, Rear fender rust (globeDELETETHIS USER)
check your pm
Old Aug 7, 2006 | 10:12 AM
cpmike's Avatar
you can find pre-formed patch panels for 90-93 accord sedans... and if you need it for a coupe, you can cut it off along the thin edge and the rest will be useful...
keystone sells them if you have one local, or search for "patch panel" on cb7tuner.com for more information... this guy sean (noxidea) buys extra sets and sells/ships them to ppl who cant buy them themselves locally...
in1accord007
Oct 30, 2010 05:56 PM
dumpedhard
Mar 16, 2009 04:22 PM
go2sleep
May 18, 2006 06:36 PM
standbackimapro
May 15, 2006 01:46 PM
OneFire
12
Apr 28, 2004 08:04 PM
