help: Buying a used JRSC kit for my ITR motor
Old Jun 17, 2006 | 02:44 PM
PaChiLa Leader's Avatar
Default help: Buying a used JRSC kit for my ITR motor
i am about to purchase a used JRSC kit.. what do i need to know and what's to check... the seller told me it's in mint condition with low km on it.. but i have no clue what's need to be checked before buying it..
can someone help me out here?
thanks~
Old Jun 17, 2006 | 02:51 PM
Haleiwa-Brando's Avatar
Default Re: help: Buying a used JRSC kit for my ITR motor (PaChiLa Leader)
You need to contact user name: mythias
He's more or less the ITR supercharger guru around here.
Old Jun 17, 2006 | 02:59 PM
Default Re: help: Buying a used JRSC kit for my ITR motor (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">You need to contact user name: mythias
He's more or less the ITR supercharger guru around here.</TD></TR></TABLE>
thanks~
Old Jun 17, 2006 | 04:37 PM
MilFhunter001's Avatar
Don't do it..
Old Jun 17, 2006 | 05:19 PM
JjuuN R's Avatar
Default Re: help: Buying a used JRSC kit for my ITR motor (hondabitch)
also ask in the Forced Induction forum, you'll get alot more responses in there
Old Jun 17, 2006 | 06:40 PM
88 rex's Avatar
Default Re: help: Buying a used JRSC kit for my ITR motor (JUN.R)
How much are they asking?
Old Jun 19, 2006 | 07:43 PM
Mythias's Avatar
PM sent.
Old Jun 19, 2006 | 07:59 PM
nholmes's Avatar
Mythias will take care of ya.
Old Jun 20, 2006 | 09:54 AM
Spunkster's Avatar
YOu need to look at the rotors to make sure they are not nicked, chipped or have heat damage. THere should be an epoxy coating on the rotors...if it has gotten too hot, the epoxy coating will be gone. Also download the pasts list from http://www.jacksonracing.com and the instructions and check to make sure you got everything.
I would skip installing the fuel pressure regulator and the pressure sensor and get larger injectors and perhaps the Hondata s300 to get the car tuned properly.
Mine is intercooled with the LHT setup and is making 265hp and 185 lb/ft tq at about 7-8 psi with Comptech race header.
Old Jun 20, 2006 | 01:04 PM
88 rex's Avatar
Default Re: help: Buying a used JRSC kit for my ITR motor (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">
Mine is intercooled with the LHT setup and is making 265hp and 185 lb/ft tq at about 7-8 psi with Comptech race header.</TD></TR></TABLE>
I'm starting to hear more and more about this set-up. Sounds like a lot more people are starting to supercharge with the LHT set-up.
Old Jun 20, 2006 | 04:43 PM
an2ny888's Avatar
i'm curious about the lht setup. would it prevent high boost from chipping away the epoxy coating on the rotors? i was thinking it wouldn't since the lht is located after the rotors
Old Jun 20, 2006 | 04:52 PM
team slide-squad's Avatar
go with a vortech supercharger........way better
Old Jun 20, 2006 | 06:38 PM
88 rex's Avatar
Default Re: help: Buying a used JRSC kit for my ITR motor (sil916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sil916 &raquo;</TD></TR><TR><TD CLASS="quote">go with a vortech supercharger........way better</TD></TR></TABLE>
I would tend to diagree with you for many reasons, but all of which you can find if you search.
Old Jun 20, 2006 | 07:04 PM
cambopheonix56's Avatar
Default Re: help: Buying a used JRSC kit for my ITR motor (88 rex)
JRSC has a waaayyyyy better curve.
Old Jun 20, 2006 | 07:38 PM
Mythias's Avatar
As 88 rex hinted around at, the OP did not make this thread to argue which is better.
PaChiLa Leader- I sent you a rather lengthy PM that I hope you find helpful.
jummpmann
Jun 24, 2007 05:13 PM
PaChiLa Leader
Jun 17, 2006 05:59 PM
Aerodeck
Oct 22, 2002 11:46 PM
InfamousRS
Jun 29, 2002 11:04 AM
i 4
Jul 3, 2001 11:28 AM
