how do you put back together cargo box CRX
Old Jun 17, 2006 | 11:32 AM
twotalefox's Avatar
Default how do you put back together cargo box CRX
1988 crx
cargo box
and the thing that flips down and up. so you can lay it flat.
i dont know the best way to explain it?
how do you screw it back together i see the 2 screw for both sides?
pics please.??
Old Jun 17, 2006 | 12:16 PM
thesmogman's Avatar
Default Re: how do you put back together cargo box CRX (twotalefox)
Yes two screws on each side. It is screwed to the body with plastic inserts.(which are usually stripped out) you can replace the plastic inserts with a set from kragen and or such. Pull up your carpet and you will see them.
Edit:: You have to screw them in from the back of the car!
Sorry no pic's because no camera.
If you are talking about the covered tray/backseat area there are the same plastic inserts and I think it's six screws. If you want to do it at the same time
GrassNinja
Audio / Security / Video
Oct 13, 2008 12:46 PM
Custom Rex
Jun 21, 2005 08:25 PM
GroundZer0 336
Mar 5, 2003 02:48 PM
BanEL
Dec 4, 2002 07:59 PM
