what sensors are these?
Old Apr 16, 2002 | 06:25 PM
keebler65's Avatar
Default what sensors are these?
ok, i am installing a b16 and was wondering what three of the senors are on the block. i am talking about the 3 in a vertical row to the left of the oil filter. the top one has one wire, the middle has two wires, and the bottom has one wire. i am pretty sure that the top one is the knock sensor, but what are the other two?
thanks
Old Apr 16, 2002 | 06:35 PM
tinkerbell's Avatar
Default Re: what sensors are these? (keebler65)
teh one with two pins is the radiator fan switch and the bottom one is oil pressure
t..
and yes top one is KS
[Modified by tinkerbell, 1:35 PM 4/17/2002]
Old Apr 16, 2002 | 06:57 PM
keebler65's Avatar
ok but i thought that the oil pres. was on the vtec assembly. is there two sensors or somethin?
Old Apr 17, 2002 | 02:16 AM
kinesistech's Avatar
The one wire oil sensor on the block is for the light in the dash. The 2 wire sensor on the solenoid is for vtec.
Old Apr 17, 2002 | 06:11 PM
keebler65's Avatar
but i mean are there two oil sensors? because i was talking about the one by the oil filter, if that is an oil sensor. would it make sense to have two oil sensors?
thanks for the replies
Old Apr 17, 2002 | 06:15 PM
tinkerbell's Avatar
yes, one is for the oil pressure light on your dash (inaccurate/insensitve) and is located on the back of the block, leave it off and you oil light will remain 'on'
teh other is the VTEC oil pressue - not engine oil pressure, so yes it would make sense...
t..
Old Apr 17, 2002 | 06:47 PM
keebler65's Avatar
Default Re: what sensors are these? (tinkerbell)
very kewl. thats what i needed to know. thankyou for clearing that up
GoLowDrew
Dec 4, 2014 08:07 AM
lazlong
Dec 20, 2011 03:48 PM
I got a honda
Oct 15, 2005 09:40 PM
SleeprCivic
Jun 20, 2003 10:14 AM
