90-93 DA brakes installed in 89 HF - brake pedal thumps to the floor
Old Jun 17, 2006 | 07:36 AM
EF_ST@TUS's Avatar
Default 90-93 DA brakes installed in 89 HF - brake pedal thumps to the floor
I just got the brakes finished last night
They feel wierd now, They kind of thump like the rotors are warped....
Brembo Blanks, Hawk pads, and this are next:
http://fastbrakes.com/shop/pro...d=133
I guess I have to wait until then to know what the problem is. Any other suggestions as to what it could be?
Old Jun 17, 2006 | 07:38 AM
EF_ST@TUS's Avatar
Default Re: 90-93 DA brakes installed in 89 HF - brake pedal thumps to the floor (Lost_in_a_world_so_cold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold &raquo;</TD></TR><TR><TD CLASS="quote">I just got the brakes finished last night
my rims look chrome
Old Jun 17, 2006 | 07:48 AM
mntuner2's Avatar
Could be anything on the hub including:
corroded alloy wheels
warped rotors
warped/damaged hub
messed up tires
improperly torqued wheels
Your best friend in this situation is a one of those dial gauges that lets you take runout and parralleism measurements of your braking/wheel system.
Old Jun 17, 2006 | 08:05 AM
Got_soy's Avatar
Default Re: 90-93 DA brakes installed in 89 HF - brake pedal thumps to the floor (mntuner2)
how tight did you go on the lugnuts?
Old Jun 17, 2006 | 08:11 AM
EF_ST@TUS's Avatar
Not tight at all really, i havent even torqued down the axle nut, only with my hands.
Old Jun 17, 2006 | 08:13 AM
EF_ST@TUS's Avatar
at first the pass side rotor was locked in place, probably because of rust, until i dropped the car down and moved it back a little it poped and was free. Now pass side rotor thumps on braking. Is my steering going to turn easier because of more wieght at the wheels? It seemd so yesterday, but again i only drove it for like 2 min.
I'm gonna drive it o work and see what happens
Modified by Lost_in_a_world_so_cold at 9:34 AM 6/17/2006
Old Jun 17, 2006 | 09:07 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: (Lost_in_a_world_so_cold)
warped rotor or bleed them again is my guess...
Old Jun 17, 2006 | 06:00 PM
EF_ST@TUS's Avatar
It only shakes on acceleration from the right side, just cruising it doesn't shake. Any suggestions? warped hub?
I need to be able to hit V-TAK yo'!! lol
Old Jun 17, 2006 | 08:29 PM
EF_ST@TUS's Avatar
That was seriously a joke...... Bump for some help
Old Jun 17, 2006 | 09:03 PM
harmonator84's Avatar
Default Re: (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">try tightening all your nuts down first you idiot</TD></TR></TABLE>
X2
Old Jun 17, 2006 | 09:07 PM
EF_ST@TUS's Avatar
Default Re: (harmonator84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">
X2</TD></TR></TABLE>
You gotta be fuhking kidding me.
Old Jun 17, 2006 | 09:10 PM
EF_ST@TUS's Avatar
Will a warped hub only shake the car on accel.? its smooth when i am going steady and shakes when i get on the gas.
Old Jun 17, 2006 | 09:11 PM
jk man
no seriously it sounds to me like you might need to bleed the brakes
Old Jun 17, 2006 | 09:13 PM
EF_ST@TUS's Avatar
Bleed front and rear?
P.S. I weigh 155 and i know its not the same as an impact gun, but i was standing on my 1/2" drive socket and it tightened pretty well. The guys at the gas sation ccharge $5 to impact them....cheap bastards..
Old Jun 17, 2006 | 09:17 PM
EF_ST@TUS's Avatar
http://fastbrakes.com/shop/pro...d=133 </TD></TR></TABLE>
Think this will solve my problem?+ a good bleeding.
Old Jun 17, 2006 | 09:20 PM
hmm its saying page not found on your link..???
Old Jun 17, 2006 | 09:23 PM
EF_ST@TUS's Avatar
I already have 4040 prop valve.Thanks to tyson
Old Jun 17, 2006 | 09:25 PM
hmm comes to a page about bodykits???
Old Jun 17, 2006 | 09:26 PM
EF_ST@TUS's Avatar
88-95 Civic/CRX 15/16 master cylinder $120.00
15/16 master cylinder used to restore the pedal travel to stock when using the larger OEM calipers on the 11" Civic/CRX upgrade. Applications 88-91 CRX 92-95 Civic 88-91 Civic
Old Jun 17, 2006 | 09:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold &raquo;</TD></TR><TR><TD CLASS="quote"> 15/16 master cylinder used to restore the pedal travel to stock when using the larger OEM calipers on the 11" Civic/CRX upgrade. </TD></TR></TABLE>
i think that will fix her
good luck and let us know if it works because i am thinking about doing the same upgrade.
Old Jun 17, 2006 | 10:00 PM
EF_ST@TUS's Avatar
will do
Old Jun 18, 2006 | 05:32 AM
mntuner2's Avatar
Did you tighten down your axle first before you made this decision. If the car is shaking the prop valve or a mc will not fix your problem, unless they are making the pads stick to the rotors. You should go buy a tool to diagnose the problem accurately. Much cheaper than guessing at what parts are bad. Been there done that. Good luck to all.
Old Jun 18, 2006 | 05:33 AM
mntuner2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 &raquo;</TD></TR><TR><TD CLASS="quote">...
Learn how to use this and you will save thousands on car insurance. I mean car parts.
Old Jun 18, 2006 | 07:53 AM
EF_ST@TUS's Avatar
Default Re: (mntuner2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 &raquo;</TD></TR><TR><TD CLASS="quote">Did you tighten down your axle first before you made this decision. If the car is shaking the prop valve or a mc will not fix your problem, unless they are making the pads stick to the rotors. You should go buy a tool to diagnose the problem accurately. Much cheaper than guessing at what parts are bad. Been there done that. Good luck to all.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold &raquo;</TD></TR><TR><TD CLASS="quote">Bleed front and rear?
P.S. I weigh 155 and i know its not the same as an impact gun, but i was standing on my 1/2" drive socket and it tightened pretty well. The guys at the gas sation charge $5 to impact them....cheap bastards..</TD></TR></TABLE>
Brembo blanks, hawk pads, and M/C booster so my pedal doesn't just go to the floor!! </TD></TR></TABLE>
If I have new parts mostly, I can tell what old parts are bad. The pads that are on right now throw dust like crazy
Old Jun 18, 2006 | 11:15 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lost_in_a_world_so_cold &raquo;</TD></TR><TR><TD CLASS="quote">Will a warped hub only shake the car on accel.? its smooth when i am going steady and shakes when i get on the gas.</TD></TR></TABLE>
Lug nuts need to be tightened.
