Question for 6th gen stock suspension alignment
Old Jun 17, 2006 | 04:39 AM
AnAccordIsForever's Avatar
Default Question for 6th gen stock suspension alignment
I will be having an alignment done soon on the car(sig). The suspension is all stock - springs, struts, bushings, wheels, everything, not lowered or anything. I saw in the manual that it calls for a slight rear toe-in (2mm) and 0 front toe.
I am interested in trying out a slight front toe-out (1/8" or 1/16" maybe?) and a slight negative camber in the front (1/4° to 1/2°) but just wanted to run it by you guys and see what you think. Should I just stick to the optimum specified in the manual and avoid any adventure or should this be fine ?
Old Jun 17, 2006 | 07:42 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Question for 6th gen stock suspension alignment (AnAccordIsForever)
Wrong forum. This forum is for discussing wheels and tires. Try posting in the Suspension forum. They should be better able to help you...
seatownda9
Jun 14, 2011 04:46 PM
type B16
Oct 23, 2006 12:55 PM
AnAccordIsForever
Suspension & Brakes
Jun 17, 2006 06:34 PM
digitalh3lix
Suspension & Brakes
May 8, 2005 11:23 AM
turboman
Suspension & Brakes
Apr 26, 2005 06:28 PM
