doing a "engine trade"
Old Jun 16, 2006 | 10:12 PM
Wannabe JDM's Avatar
Default doing a "engine trade"
so a guy comes up to me and asks me to swap the engines between 2 efs. one is already swapped with a b18a1 and the other has the stock motor. i figure all it would involve is guttingeverything from one car and sticking it in the other.
but i was talking to some guys and they tell me that its not that simple and it wont work blah blah blah.
it makes sence in my head that it would work, but then again ive never worked on efs before.
can anybody enlighten me on why this probably wont work and maybe point me in the right direction? thanks Zach
Old Jun 16, 2006 | 10:15 PM
crxnj's Avatar
Default Re: doing a "engine trade" (slowej)
it really depends...for example if they're both si's with mpfi already you just swap..but if its a dx then you gotta convert to mpfi,,then if its a std you gotta convert to mpfi and also get some dx/si hubs...
Old Jun 16, 2006 | 10:33 PM
its an si w/ the b18a and a dx with the d15. the 2 motors need to be swapped between the 2.
Old Jun 16, 2006 | 10:39 PM
ok just found out that the motor in the dx is a d15b7 out of an eg. doe that make life more difficult or easy?
Old Jun 16, 2006 | 10:42 PM
crxnj's Avatar
Default Re: (slowej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowej &raquo;</TD></TR><TR><TD CLASS="quote">ok just found out that the motor in the dx is a d15b7 out of an eg. doe that make life more difficult or easy?</TD></TR></TABLE>
depends...did they convert the dx to mpfi or did they just keep the dx intake manifold and distibutor on the d15b7?
if they converted to mpfi fuel injection already this **** should be easy for you..also have to find out if they converted the dx to obd1 or just kept it obd0...Not sure..
E-AT_me
Feb 12, 2008 05:13 AM
GsrTurboCRX88
Aug 22, 2006 07:59 PM
feelsfast
Oct 6, 2004 04:34 AM
TONEBONE
Jul 22, 2002 06:29 AM
hfracer420
Feb 12, 2002 07:54 AM
