Cams!
Old Apr 16, 2002 | 05:53 PM
B00ST2nR's Avatar
Default Cams!
Is the GS-R cams the same as the Civic Si Cams??
I know that the 2000-2001 ITR cams are the same as the CTR cams, but I was wondering if the GS-R and Si's have the same cams as well.... LMK-
Old Apr 16, 2002 | 06:03 PM
threatcon13's Avatar
New User
Default Re: Cams! (GS-R)
nope. its a different head. b16a for SI and b18c1 for GSR.
Old Apr 16, 2002 | 07:25 PM
B00ST2nR's Avatar
Default Re: Cams! (ALLMOTORDC2)
So if my friend swapped in some B18C1 cams in his B16A motor, will it give him gains? Is the GS-R cams bigger? Got any specs on both?
Old Apr 16, 2002 | 07:30 PM
hybridreams's Avatar
Don't have specs or anything but I've heard on this board that there are slight gains. Very slight gains.
Old Apr 16, 2002 | 09:51 PM
blacksheep's Avatar
If I'm not mistaken, CTR cams are slightly different from ITR cams. I think the CTR cams are a little better for a drop in mod without tuning.
Old Apr 16, 2002 | 10:36 PM
B00ST2nR's Avatar
Default Re: Cams! (blacksheep)
I read that the 97-99ITR cams are different, but the 2000-2001 ITR cams are the Same as CTR cams...
Old Apr 16, 2002 | 11:13 PM
flybert's Avatar
The exhaust cams on the Integra type r and ctr are the same, but the ctr has a larger intake cam.
Old Apr 16, 2002 | 11:48 PM
nfn15037's Avatar
Default Re: Cams! (flybert)
CTR intake cam has 3 degrees more duration than the ITR cam.
Old Apr 17, 2002 | 12:11 AM
IgniteTeg's Avatar
Default Re: Cams! (nfn15037)
Does anyone know if the Itr cams can handle the stock gsr valvetrain? Or it needs to be upgraded? Btw when changin out the cams. Would it be better to just change out the intake side only and keep the gsr exhaust side? Or change them both out for itr? Keep in mind I'm goin to turbo it. So would the itr cams benefit me for turbo or keep my stock gsr one? Thanks for the help.
Old Apr 17, 2002 | 02:10 AM
ingrate's Avatar
25 Year Member
Default Re: Cams! (IgniteTeg)
GSR valve springs can handle ITR cams just fine.. if you want, you could just swap in the intake cam only, but unless your funds are really low, why not get both? if you're going to turbo your car, the ITR cams probably wouldn't hurt, but then again it's not really necessary. turbo GSR is fast enough on stock cams
Old Apr 17, 2002 | 07:15 AM
qtiger's Avatar
97-99 ITR intake cam has 3 degress less duration than the CTRs, but they fixed that for 2000-2001.
GSR cams have a longer duration than b16 cams and can make for a little cheap power.
Old Apr 17, 2002 | 08:48 AM
IgniteTeg's Avatar
Default Re: Cams! (In7egrity)
Thanks In7egrity. Guess i'l be gettin 00-01 itr cams then anyone know a good place?? How do I know if their the real itr cams that i'm gettin any descriptions or marking that I can tell? I don't want to get ripoff and how much do you think I should pay for new and used for 00-01 itr cams??? Thanks.
Old Apr 17, 2002 | 08:51 AM
owen_the_soyboy's Avatar
the GSR cams are said to be better than <U>gen 1 automatic B16 JDM cams</U> but not anything special in comparison to civic Si cams.
dont waste your time swapping out Si cams for GSR cams. really.
ITR or CTR cams are a completely different story though.
Old Apr 17, 2002 | 12:15 PM
B00ST2nR's Avatar
Default Re: Cams! (owen_the_soyboy)
Well the thing is, I'm gonna be replacing my GS-R cams for ITR's. My friend has a 2000 SI and wants to swap my stock Cams for his...
Old Apr 17, 2002 | 12:18 PM
Acronym's Avatar
I was planning on droppin ITR cams in my GS-R but if the CTR cams are better when it comes to drop without tuning so much i might have to take a look into that!! thanks
Old Apr 17, 2002 | 12:27 PM
Default Re: Cams! (Acronym)
really, there is virtually NO market for GSR or civic SI cams.
the only buyer is someone that has a bare head and will settle for those stock cams in the time being before they get enough loot for a nice set of cams.
how else do you think I did NOT get rid of my GSR cams in the year+ that they were out of the car? I couldnt give them away!
Old Apr 17, 2002 | 01:20 PM
gsxr's Avatar
i heard that CTR intake cams used with ITR exhaust cams is a good setup....do anybody have this setup on a stock gsr motor??
Old Apr 17, 2002 | 01:26 PM
B00ST2nR's Avatar
Default Re: Cams! (gsxr)
the ITR exhaust cam is the SAME cam as the CTR...
-Championship-
Dec 6, 2006 04:55 PM
integra95gsr
Jan 22, 2006 06:43 PM
crackerjacker006
Aug 23, 2005 11:05 PM
compwc18
May 22, 2005 05:05 PM
kim_2_da_chee
20
Jul 27, 2004 11:35 AM
