b series axles into my crx hubs
Old Jun 16, 2006 | 09:06 PM
2poor2tune's Avatar
Default b series axles into my crx hubs
my axles are hitting the hubs when they are tightened down from the spindle nut. i put a spacer in and it got better but i dont think it was enough. i need to know if this is a basic procedure while doing this swap. b16 into crx. please help. thanks
Old Jun 16, 2006 | 09:12 PM
CRXBart's Avatar
Default Re: b series axles into my crx hubs (2poor2tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2poor2tune &raquo;</TD></TR><TR><TD CLASS="quote">my axles are hitting the hubs when they are tightened down from the spindle nut. i put a spacer in and it got better but i dont think it was enough. i need to know if this is a basic procedure while doing this swap. b16 into crx. please help. thanks</TD></TR></TABLE>
You have to remove the dust seal ring.
Old Jun 16, 2006 | 09:13 PM
2poor2tune's Avatar
cool i will do that real quik and let you know how it goes. thanks. and its just the peice that is on the inside of the hub bearing right?
Old Jun 16, 2006 | 09:15 PM
CRXBart's Avatar
Default Re: (2poor2tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2poor2tune &raquo;</TD></TR><TR><TD CLASS="quote">cool i will do that real quik and let you know how it goes. thanks. and its just the peice that is on the inside of the hub bearing right?</TD></TR></TABLE>
YEp, there is a rubber peice on the axle that needs removed too.
Old Jun 16, 2006 | 09:50 PM
2poor2tune's Avatar
what rubber peice? the one in the middle. can i take it off while the axle is on. i really dont wqant to do that again i hate removing thiose things. thanks tho it worked and my rotor dust shield was the thing rubbing like crazy.
Old Jun 16, 2006 | 09:57 PM
crxnj's Avatar
its on the end of the axles (hub side) Not all axles come with them on though,,but ill take a pic of it and put it up give me a min.
Old Jun 16, 2006 | 10:04 PM
2poor2tune's Avatar
the only rubber peice i see on the hub side is a little thin rubber the looks like it would be beetween the bearing and the axle. it isnt abs if thats what your thinking. if all this doesent help i guess i will post a pic but if we can get threw this without one man would that be great. sorry im lazy but if you need it i will give it. thanks
Old Jun 16, 2006 | 10:07 PM
crxnj's Avatar
Default Re: (Mr.speaker)
Old Jun 16, 2006 | 10:09 PM
2poor2tune's Avatar
so that peice i just discribed has to go. dammit. if i made a dime every time i touched my suspension i would be rich. just the way i get it apart. im gonna try the real way to swap an axle
Old Jun 16, 2006 | 10:12 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2poor2tune &raquo;</TD></TR><TR><TD CLASS="quote">so that peice i just discribed has to go. dammit. if i made a dime every time i touched my suspension i would be rich. just the way i get it apart. im gonna try the real way to swap an axle</TD></TR></TABLE>
You might not have to..does it bind or not while moving the wheel.? on mine it binded so it had to go
Old Jun 16, 2006 | 11:02 PM
Mr.Death's Avatar
Default Re: b series axles into my crx hubs (Mr.speaker)
Old Jun 17, 2006 | 12:12 AM
2poor2tune's Avatar
thanks alot guys. i got it all taken care of they spin like a dream now. well they could be rotas but stealies are fine for now. thanks
ClubRX
30
Sep 16, 2011 02:03 PM
slowB20ej8
Jun 23, 2007 08:32 AM
hatch2023
Mar 23, 2006 01:39 PM
Grnade
Sep 8, 2004 01:00 PM
y_design
13
Aug 19, 2004 09:37 PM
