b16 back to d16a6
already guys this is my question i had a b16a that was in my crx and i took it out cause i want to go back to stock i need to know what wires they spliced and **** like that cause my motor wont start it will turn over but just wont start checked compression spark, spark plugs,dizzy and cap and rotor please i need help have everything connected just 2 things on the wire-harness didn't set straight to me please help
wat bout the ecu i have a 89 si ecu in there
and wat is the cylinder compression on that motor? i got 160 to 165 on all my cylinders
wat bout the ecu i have a 89 si ecu in thereand wat is the cylinder compression on that motor? i got 160 to 165 on all my cylinders
yes im pretty sure i do it might be an integra wiring harness im not sure has an extra connection to it so it might be integra i would have to see man but wat wire did they splice into for the ecu
4LugR
11
Jun 30, 2005 07:21 PM
white91rex
Apr 29, 2005 11:45 AM
