delsol body flex
Old Jun 16, 2006 | 07:55 PM
postman's Avatar
Default delsol body flex
has anyone fab'd something up to help stop this. Also dose sanyone know the exact weak spots. is it the floor, targa area. seems to not be nearly as bad when the tops not off. i was thinking maybe some braces connecting the front and back pillars to hold them solid all the time. or a cage with extensions to the pillars. all opinions and suggestions welcome
thanks,
postman
Old Jun 18, 2006 | 09:41 PM
1helluvahatch's Avatar
Default Re: delsol body flex (postman)
do you experience it in tight corners or something? i've never experienced it.
Old Jun 19, 2006 | 12:32 PM
postman's Avatar
Default Re: delsol body flex (DaDelSolguy)
funny your the first thats ever said that
Old Jun 19, 2006 | 01:31 PM
C1V1C's Avatar
made this bar for a friend out of 1.5" DOM tubing, said it stiffened the chassis a lot.
Old Jun 19, 2006 | 02:24 PM
linx's Avatar
This is a known trouble with del sols.try the bar as suggested stich welding will also help
Old Jun 19, 2006 | 02:30 PM
postman's Avatar
Default Re: delsol body flex (C1V1C)
thats what i figure i was going to try. what do you guys think about from front to back as well
Old Jun 20, 2006 | 12:51 PM
JCracer723's Avatar
is really hard to find delsol owners that care or know about body flex..
most confuse it with body roll.. and its NOT the same thing..
ive been tryin to think about a solution to the problem. or somethin to help minimize it for a while..
i know a cage would be the best ideal thing to do.. but me bein 6 feet tall its already hard enough to get in and out of the car.. imagine with a freaking cage in there..
othere options would be foam, braces, stich weld the floor, but each has its pros and cons..
foam is messy.. and i havent been able to find any products that are injected..
braces work.. but what kind of braces to make.. where to place them. wheres the weakpoint.. its really hard to think where to begin bracing.. also limited space in the cabin or under car..
stich welding takes alot of time and you have to be really careful not to mess up the whole body..
been thinking on beefing/bracing the middle tunel. right where the exhaust travels through.. but there isnt much space under there..
Old Jun 20, 2006 | 01:40 PM
postman's Avatar
Default Re: delsol body flex (JCracer723)
im probably going to be gong into this extensively in a few weeks. i might use a chassis ear to locate the weak points. will try to do a wite up on this.
Old Jun 20, 2006 | 04:52 PM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">im probably going to be gong into this extensively in a few weeks. i might use a chassis ear to locate the weak points. will try to do a wite up on this.
chassis ear? care to explain...
and what method are you planning on using? cage?braces? foam?
Old Jun 20, 2006 | 05:32 PM
postman's Avatar
chassis ear is something mainly used for air leaks in the cabin. like when old people are like when i drive down the road this weird noise starts. snap on makes them its a box with 4 or 6 clamps that you can hook up to parts of the chassis to hear for noises. i figure if i can find where the squeaks and creaks are the loudest should be closest to point of flex.
i will probably just make some braces, but i have the feeling if im going to have to make enough braces that i might as well build a cage. maybe a cage with extensions to certain parts that need it. plus i love to hug them turns in the country(no tokyo drift ****)so a cage might be a good idea in general.
Old Jun 20, 2006 | 05:52 PM
JCracer723's Avatar
yes, the more i think about braces.. the more i end up just thinkin about going with a cage.. i just need to find someone in so cal to fad me a custom one..
Old Jun 21, 2006 | 07:03 AM
stillrockin18s's Avatar
Just corner slower , J/K
Make a pillar bar like the one pictured, it should help. I have seen a bunch of people "stich weld" all the rear panels on Integra's and Acccords to help body roll, not sure if that's gonna help much on you sol or not. If you want to try to do a bar this weekend let me know, I've been wanting to do one for the teg as well.
Also some strut bars may stiffen things up a bit.
Hit me up when you get in town, I have a wedding to go to on Saturday so hit me up before 2 if you can.
Old Jun 21, 2006 | 07:07 AM
redsolturbo's Avatar
sumo power over here in the uk sell eg civic chassis lower braces that run DOWN the legnth of the car (one each side). unfortunatully they dont make them to fit the eg2 delsol
though im sure a set could be made to fit or a copy could be made, though if you pop your side skirts off the sol you have a nice long groove ( U shaped) that runs down the legnth of the sills. if you were brave enougth you could get 2 solid titanium or stainless bars cut to that diamiter and push them in the weld them up. if i had a scrapper here i would actully try it, but i paid £3700 for my sol over here and im not going to screw it up on a whim/test :lol:.
Old Jun 21, 2006 | 07:19 AM
Default Re: delsol body flex (redsolturbo)
also to add the bmw m3 has the same problem, basicly on cornering the chassis twists due to the chassis being thin and having no support at all between the front 2 and rear 2 wheels, the s2000 counters this by having that fat heftey thick internal oem brace built into its chassis than joins all 4 corners together (i belive porsche also has a similar brace). saloon cars dont get the problem as the roof is all joined together , so chassis flex along the center of the car and twist is limited greatly.
another option could be to build a full car undertray which would provide much lower drag resistance and is braced on the top side stregnthen the chassis in a similar way.but at a guess thats as much work as making a full cage from scratch :lol:
Old Jun 21, 2006 | 07:26 AM
http://www.do-luck.co.uk/fsb.htm
thats those bars!
Old Jun 21, 2006 | 09:31 AM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsolturbo &raquo;</TD></TR><TR><TD CLASS="quote">sumo power over here in the uk sell eg civic chassis lower braces that run DOWN the legnth of the car (one each side). unfortunatully they dont make them to fit the eg2 delsol
interesting.. just look at the bar.. pretty much the same concept they use for hot rods.. ive heard about that space under the skirts. i will check it out and see what it can be done..
thanks for the input
Old Jun 24, 2006 | 09:59 AM
postman's Avatar
bu t if you were to make a bar like that what would you weld to the body
Old Jun 24, 2006 | 04:06 PM
HiProfile's Avatar
Well for old f-bodies (firebird/camaro), they used to connect the front/rear subframes together with big fat bars. There's also the 'torque tubes' used in some muscle cars, mainly for keeping the body between the flywheel and diff from twisting. My 67 firebird also has a plate under the floor shifter, more or less like a 4-point lower tie-bar for a civic/integra. Its a convertible, and they obviously had to do something since it was one of the first uni-body convertibles.
There's also another way to brace it, you could go from somewhere near the rear shock mount to the door sill. You could have one go forward 1/2 or 1/4 into the door sill and still be easy to get out for a bigger guy. IIRC, that old 50's mercedes benz with the gull wings had very tall door sills to add reinforcement there.
The other thing would be to contact the roadrace forum guys, as they no doubt could give you some advice. Even other non-honda forums could give some general help, since there are a few targa-top vehicles.
Old Jun 24, 2006 | 05:25 PM
jeremydde's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsolturbo &raquo;</TD></TR><TR><TD CLASS="quote">http://www.do-luck.co.uk/fsb.htm
thats those bars! </TD></TR></TABLE>
Those bars suck don't buy them. They are over-priced and WEAK. They are made of thin aluminum and mount up on to the floor where the strength isn't needed. I installed some on a R32 skyline and they made no difference. Not to mention one came cracked already straight from Do luck.
Old Jun 25, 2006 | 08:39 PM
JCracer723's Avatar
Default Re: delsol body flex (jeremydde)
ok i did some search on the miata subframe braces.. and they have some pretty good stuff..
Old Jun 26, 2006 | 06:01 AM
postman's Avatar
thats hot shiat. the miata style looks mre promising than the do lucks.
makeh6
Jun 12, 2017 01:15 AM
UnLuckyy
28
Sep 18, 2010 05:45 PM
myronwong
17
Feb 2, 2006 06:15 PM
redfox
Feb 29, 2004 02:23 PM
93EH6
Jan 13, 2003 09:14 PM
