temperature knob
Old Jun 16, 2006 | 03:13 PM
supracrx's Avatar
Default temperature ****
is tehre a specific way besides the white part lining up the **** suppose to sit into the shaft? the shaft has some splines and stuff but is there a certain way of putting it in? also where can i pick up the **** for the temperature control...my **** is broken and everytime i turn it it just slides on the shaft....SL honda wants bout $20 for it..any cheaper?
Old Jun 16, 2006 | 03:29 PM
EL Vap133's Avatar
Default Re: temperature **** (supracrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supracrx &raquo;</TD></TR><TR><TD CLASS="quote">is tehre a specific way besides the white part lining up the **** suppose to sit into the shaft? the shaft has some splines and stuff but is there a certain way of putting it in? also where can i pick up the **** for the temperature control...my **** is broken and everytime i turn it it just slides on the shaft....SL honda wants bout $20 for it..any cheaper?</TD></TR></TABLE>
Well if it is broken and just slides when you turn it, why would you even want to know where the white part lines up at? Its not like it's going to do you any good if it doesn't work. Know what I mean?
Old Jun 16, 2006 | 07:37 PM
supracrx's Avatar
yea i kno...what i'm asking is ....is there anything in the back where the splines go on in a specific way..or does it just slide in just like that?
ii m not sure is it the **** or the shaft...
Old Jun 16, 2006 | 08:32 PM
JJ's civic's Avatar
Default Re: (supracrx)
just go to you local pick and pull. it should fit in your pocket and what's rule number n at a junk yard????
giff74
Apr 26, 2005 04:17 PM
besouza
Apr 4, 2005 05:15 PM
