jdm head
Old Jun 16, 2006 | 12:56 PM
hspoon's Avatar
Default jdm head
i have a jdm pr3 head, in which i believe is a 89 to 91 b16.
but i think the distributor is OBDI, what type coil i need???????
does the rotor have to be pointing to spark plug #1 o que pedo?????????
Old Jun 16, 2006 | 01:00 PM
xDicktonesx's Avatar
Default Re: jdm head (hspoon)
look at the front of the head. the year is stamped on it.
Old Jun 16, 2006 | 01:17 PM
ham's Avatar
ham
if your distributor is obd1, you need a whole distributor. the jdm pr3 head goes from 88 up to 95 i think.
(Top one)
look at the plug on the distributor, if it looks like the right side, its obd0, if it looks like the left its obd1
Old Jun 16, 2006 | 02:26 PM
hspoon's Avatar
Default Re: jdm head (ham)
on the head i think it says 92.....
can i use a distributor of a d16z6?????
in the mainfold it says PGM-Fi, the bolck is a b20b and im puttin it in a 94 civic do i need to change the manifold or any other changes
Old Jun 16, 2006 | 02:42 PM
Rywire's Avatar
http://rywire.com/store/distri...210ef
thats the dizzy you need for a obd1 ecu... td44u
Old Jun 16, 2006 | 02:47 PM
hspoon's Avatar
Default Re: jdm head (droppedcrxsi)
thanx............
what about the distributor from d16z6 for now????
Old Jun 16, 2006 | 03:02 PM
ham's Avatar
ham
if its going in a 94, then leave the distributor thats on it!
Old Jun 16, 2006 | 03:04 PM
hspoon's Avatar
but the coil doesnt work
Old Jun 16, 2006 | 03:14 PM
STREETWERKZ's Avatar
if youre working on a 94 civic..... why are you in the EF section?
either way.... i'm sure we could help you if you posted your questions a little more clearly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon &raquo;</TD></TR><TR><TD CLASS="quote">but i think the distributor is OBDI, what type coil i need???????
obd-1 DEL SOL will work. make sure its the si VTEC model.
Old Jun 16, 2006 | 03:15 PM
89s1's Avatar
no a z6 dizzy will not work, the coil that is inside that dizzy will fit into the b16 casing however.
now if you don't have a vtec dizzy or a modified non-vtec b18 dizzy then you will need a whole new distributer, the d16z6 one will not fit.
Old Jun 16, 2006 | 03:17 PM
hspoon's Avatar
Default Re: jdm head (89s1)
thanx for all of your help... p.s i love u
Old Jun 16, 2006 | 03:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon &raquo;</TD></TR><TR><TD CLASS="quote"> i love u</TD></TR></TABLE>
Old Jun 16, 2006 | 03:20 PM
hspoon's Avatar
Default Re: jdm head (STREETWERKZ)
lolz..........
E-Money
Nov 4, 2010 12:19 PM
95civicLS
May 5, 2010 08:13 AM
ProricanEF
Mar 27, 2008 09:08 AM
nevin
Aug 14, 2003 07:02 PM
RAWB
Mar 20, 2003 01:35 PM
