air conditioning help......
its possible that your compressor clutch isn't engaging. Turn on the a/c and look at the end of your compressor and look to see if the clutch is spinning with the pulley. If its not spinning your compressor won't engage
check the thermal switch on the top of the compressor it may be bad. Short across it and see if the compressor starts and cools. If it starts but does not cool look else where. Does the freon blast out when you press on the schrader valve?
Since some of your freon is in the liquid state due to the line pressure, you are dealing with a two phase system here. This means that you will still have full pressure until the charge gets very low.
yoblocher
Jun 28, 2016 08:33 PM
saveacivic
Jun 24, 2008 09:21 PM
