code 15? ignition output signal....need help
ok so i was taking off my fuel rail for a quick lil clean up and paint cause it was monstrous mess and when i was taking it off i lost that stupid little washer for the fuel feed line doh! i tried all sorts of washers and none would fit and after all that i got gas all over my engine 8(....now i finally rigged it to where it is not leaking (thanks to tinfoil! hah) but thats only for like a day cause the piece is coming in on monday but i still want to know what is causing this code 15? the car tries to crank over but nothing.... and we even tried to push start it and nothing but at first when i got it to work it ran for a lil but after a minute or so it just cut off and after that i can't get it to start
i was thinking it is cause the cylinders are flooded but why would it send a code? ive had my cylinders flooded before and it never sent a code... i can't check right now due to the fact i don't have a long enough extension to reach but does anyone have any other screnarios or things i can check?
From: I told you to wait in the truck in Texas, United States
Code 15 usually equals a bad ignitor..
See: https://honda-tech.com/zerothread?id=1656532
for trouble shooting info
and fix the gas leak before you go up in flames..
The washers are usually made of copper or aluminum.
thanks for the linkk thats what i thought it might have been...if it is this im going to be royally pissed cause its a brand new distributor 8(
and ive already had my engine on fire once lol
if the ignitor is shot it won't spark at all right? im going to check for spark later so i can narrow it down even more
Rye thats the same thing that i had with my Si. You know what to do....just change the ignitor like we did on mine......to bad you gave me your only good one
