garge sale ls swap, garret turbo kit, b16 block, gsr type R more to see come in
im starting over from scratch im going to build a drag car and i have all these parts and none are use full to me i know everyone needs something.
garret turbo and manifold 400
the hole turbo kits 700
after market 3rd and 4th cencros for ls- 75
92-95 sterring wheel and air bag- make offer
2 air bag control units-make offer
ls swap-800 it in cludes everything needed(still in car have to pull if you are serious)
ls head all new seals and guides complete head- 75
ls motor-300
b16 block bored 20 over and been honed-300
GSR motor-1600
b16 block broke driver side mount-75
92-95 civic head lights -25 a peice
92-95 perjector head lights- 30 a peice
after market coil- 15
92-95 si indash harness-50
2 distributers for gsr with no over- 70 a peice
msd rotor cap and button new in box- 40
b16/gsr oil pick up-15
ls tranny hydro-200
lsvtec motor je pistons,eagle H beam rods, scunk 2 manifold skunk 2 stage2 cams aem fuel rail, and ajustibul fuel pressure regulater-1750 (ran 13.22 at bristol drag way)
gsr head with stanless steal farea valves-500 Ready with manifold to bold on no work needed
b series red valve cover- 75
new black b series turbo manifold -160
96-98 stock tail lights-50
b series shift linkages- 50
b16 isky racing titanium valve springs-100
6 in tack-50
s200 with boost option-200
mazda b2200 and b2000 motors -200 each
Wiring harnnes for rear hatch 92-95-30
head light harness from fire wall to head light-25
92-95 ex fuse box-50
sohc high flow fuel rail-20
3 b series fuel rails-20
CX 92-95 gage cluster-30
2 brake busters for acuras-50 a peice
2 master cylinders- 25 a peice
2 clutch master cylinders-20
civc drums brand new- 25
B16/gsr oil cooler-40
water pump-35
b16 intake manifold-45
b16 main bearing caps-25
95 GSR harmonic balencer- 30
2 B16 harmonic balancers-30 a peice
timing blet cover-10
3 sets ofhead bolts b series-30 a set
home amplifer-30
power supply-50
GSR shifter-20
Re orange and black with crome-17
batery hold down-5
98 civic front seats- 50 a peace or 85 for both
95 cloth Gsr front seats- 50 a peice or 85 for both
92-95 raditor-60 used short time
bronze focal 17 in wheels(has 4000 miles on them) kumho 17x7 tires same miles
300 for wheels or wheels and tires for 600
street glow under car kit (BLUE) many settings LED-100 new in box
i have a 91 acura ls totaled if u need parts ask and ill tell u if good or not
most body parts are bad but still ask inside leather not in that great of shape all door panels,dash,everything else in the car is good
and a acura GS been totaled PM for parts
more to be posted
ask for honda parts ill probably have it
WILL CONSIDER TRADE ON ANYTHING BUT THE LS VTEC
Modified by boostedhatch85 at 7:52 PM 6/16/2006
Modified by boostedhatch85 at 4:06 AM 6/17/2006
Modified by boostedhatch85 at 6:29 PM 6/17/2006
ls motor-300
GSR motor-1600
ls tranny hydro-200
6 in tack-50
water pump-35
home amplifer-30
power supply-50
GSR shifter-20
batery hold down-5
more to be posted
