cleaning injectors
Old Jun 16, 2006 | 11:19 AM
mehheh1029's Avatar
Default cleaning injectors
Does Sea Foam really work to clean injectors cuz my throttle response hasnt been too good lately and I think its my injectors, but I dont wanna have to spend a bunch of money on new injectors cuz I'm gonna be selling it soon.
Old Jun 17, 2006 | 06:02 AM
FallenAngelHIM's Avatar
depends on what your idea of really works is and how poorly your engine has been kept. if your engine uses quality fuels, you do your routine maintenance, and don't drive like a moron, seafoam won't show much change. but if your car has been abused fairly, or is fairly old, seafoam does wonders. it restores 1 HP maybe, but will clean all carbon from your system. you'll see a nice white cloud of smoke from your exhaust if you inject it through your PCV or your intake throttle body.
Old Jun 17, 2006 | 06:04 AM
-RedneckDave-'s Avatar
Working
Default Re: cleaning injectors (mehheh1029)
To really clean injectors you can take them off and have them put in one of those harmonic cleaners. I can't think of the name of them right now but that works.
Old Jun 17, 2006 | 06:23 AM
Eddiebx's Avatar
Default Re: (FallenAngelHIM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FallenAngelHIM &raquo;</TD></TR><TR><TD CLASS="quote">depends on what your idea of really works is and how poorly your engine has been kept. if your engine uses quality fuels, you do your routine maintenance, and don't drive like a moron, seafoam won't show much change. but if your car has been abused fairly, or is fairly old, seafoam does wonders. it restores 1 HP maybe, but will clean all carbon from your system. you'll see a nice white cloud of smoke from your exhaust if you inject it through your PCV or your intake throttle body.</TD></TR></TABLE>
actually u would rpobably have less carbon deposits if you drovve like a moron, more air at higher velocities sucking **** out
Old Jun 17, 2006 | 08:59 AM
Skunk50's Avatar
just make sure to change the oil right after using Seafoam. it thins out your oil. i may have overdone it on my LS1 which caused the car to knock more now (on cold starts).
i poured in a whole bottle through the PCV hose. let the car sit overnight. next morning, drove it for about 2-3 miles to warm up the oil. changed the oil/filter.
much better throttle response and felt some power (maybe in my head). but some extra knocking when it's cold out. although knocking is a known problem in LS1 motors.
Old Jun 17, 2006 | 10:13 AM
EASY101's Avatar
* B A N N E D *
is it ok to pour that fuel injector cleaner into your gas tank?
Old Jun 17, 2006 | 10:33 AM
CfOuUcGkH CyOoUuG!H's Avatar
Default Re: (EASY101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EASY101 &raquo;</TD></TR><TR><TD CLASS="quote">is it ok to pour that fuel injector cleaner into your gas tank?</TD></TR></TABLE>
I poured STP complete fuel system cleaner in mine and it has seemed to help...
Old Jun 17, 2006 | 05:49 PM
don't pour the whole can. pour about 1/3 or half if you're feeling ballsy. i recommend 1/3 on a full tank.
kornerk12
Oct 15, 2006 01:17 PM
TheWalrus
Apr 20, 2006 09:04 AM
idriveadelsol7
Oct 9, 2005 10:47 PM
ThrillaKilla
Mar 24, 2003 04:23 PM
spencer00si
Oct 15, 2002 02:02 PM
