Which one of these is the best lube/grease to use ?
Old Jun 16, 2006 | 10:58 AM
AnAccordIsForever's Avatar
Default Which one of these is the best lube/grease to use ?
For general automotive use - like bushings, bearings, other 'lube-able' parts.
Something that does not affect rubber or cause corrosion or attract dust, safe with water etc...
Liquid White Grease
Marine Grease
Graphite Grease(powder?)
Silicon Spray
WD-40
Old Jun 16, 2006 | 11:13 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Which one of these is the best lube/grease to use ? (AnAccordIsForever)
I use a Valvoline synthetic grease or something I think. It's rated for high heat and stands up to water well. I've used it a lot on bushings, slide pins in the brakes and other things and it's held up great.
niceprelude
Detailing
16
Mar 5, 2009 07:22 AM
full Circling
Jul 9, 2007 07:35 AM
bluebeast
Nov 27, 2006 07:14 AM
JLange
Feb 21, 2003 05:42 AM
Duckz
Dec 22, 2002 07:28 AM
