Eagle rods , Bogarts and M/T slicks for sale
race season is here...
Anyone need these pieces
brand new EAgle Rods for GSR $375. firm
Stanley clear corners for the 4 dr 92-95 Civic ---$50.00...these are the real things not an APC corner , comes with the wiring harness and bulbs
Fiber Images Carbon Kevlar Lip Spoiler for 5th gen civics $550 Firm
SOLD_15x8 Bogarts for the Integras/Civics
4x100 with lugs and spacers
Mickey Thompson ET Drag 22x8x15
12 passes in mint and shiny shape
look here http://www.evotuners.com/ss51042001_splash.htm
$650. plus shipping if need be
northeast coast
anyone want these
Rota C8 Bronze 15x6.5 4x100 great condition 80% tread
195/50/15 yokohama AVS in great shape , no centercaps as they fell off $500 Firm
buyer pays shipping
or make a good offer on anything above
please no more flakes
im sick of the snow!!!
[Modified by 555R, 7:22 PM 4/27/2002]
northeast coast
anyone want these
buyer pays shipping
how much do the bogarts weigh?
thanks
chris
sorry i though this was the old post ignore the question
[Modified by 01VaS2K, 8:00 PM 4/16/2002]
thanks
chris
I am iterested in the Mickey Ts and the Bogarts, however I am running 22x8x13" M & H Slicks with 13" Bogarts right now. How would I benefit by moving up from a 13" to a 15" wheel? Thanks.
Stepping up in slick size would be like changing your final drive ratio without changing your final drive. Basically, do you hit the top of fourth when you go through the traps with those current slicks or do you have to shift into 5th before you do hit the traps? If you do need to shift into fifth, then with the larger size or tire diameter you can possible extend the gearing out far enough to be at the top of fourth when you do go through the traps.
Also this setup may allow you to have a wider contact patch if your 13's aren't nearly as wide. Sometimes to get that larger diamater tire you also have to go wider in width too.
Just trying to help
Just trying to help
Ummm. Looks like both of you are running the same tire hieght. There would be no change in the RPM in which you go through the traps.
The 13s might be a little more benefical in terms of traction as they have more sidewall.
Steve
Steve
you didnt mention this point
about top end stability with the 15s
also a 13x8 22x8x13 can have the same contact as the
15x8x22, also depends on tire pressure
it depends on the rim width as these are pretty damn wide
they stick out about an inch or so but dont rub
13x8s however have a better out of the hole traction IMO
i have them because i run big brakes
but want to get rid of them as I dont drag race
just road courses now
Yes, I e-mailed you regarding purchasing the Bogarts and Slicks, but never got a return about how much shipping would be. Please let me know! I am ready to buy! Thanks.
