y1 tranny Question
ok i put a clutch and fly wheel in my b16a swap before installing it. but now the clutch its almost adjusted to the max and the petal ingages half way still. could the throw out bear be messed up or the clutch cable. its a b16a and y1 tranny in a 90 crx si any way thanks for help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 »</TD></TR><TR><TD CLASS="quote">make sure u turn that plastic nut in and take the slack out of it.</TD></TR></TABLE>
i did this and still acts like its not engaging properly i'l l try the pedal adjust but i think some how the throw out bearing came loose or something it work perfect befor i did the swap, and it worked befor i put the tranny back on the b16.
thanks
thanks
What kind of clutch is it? Cuz I had this same problem with my ACT clutch. Freakin sucked. And did you replace your clutch cable when you replaced the clutch?
I had the same problem one time my problem was that the throw out bearing was not put on wright were the little spring that clips on the back of the bearing ! you know were the clutch leaver the spring clips behind that. that may be the same problem you are having but good luck to you!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseries!EF!hatch »</TD></TR><TR><TD CLASS="quote">I had the same problem one time my problem was that the throw out bearing was not put on wright were the little spring that clips on the back of the bearing ! you know were the clutch leaver the spring clips behind that. that may be the same problem you are having but good luck to you!!!</TD></TR></TABLE>
That sounds like it could be it. It could also be that your cable is stretched out too much or that your pressure plate can be defective.
