TPS mounting screws
Old Jun 16, 2006 | 08:24 AM
LawlessOne's Avatar
Default TPS mounting screws
I'm sure I saw it here before, but now I can't find it.
I'm trying to figure out the size of the screws that hold the TPS to the TB so I can replace the factory crap with an allenhead, or at least something other than smooth.
Thanks!
Old Jun 16, 2006 | 08:31 AM
Ross 2.0's Avatar
In a Junkyard near you.
easy way to do it without a lot of fuss is to cut a slit into the screw heads with a hacksaw blade or a cutoff wheel so you can use a flathead screwdriver to turn them.
Old Jun 16, 2006 | 08:41 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: TPS mounting screws (LawlessOne)
are you referring to thread size?
I want to say it's either an M6 or M8, probably M6. I know I saw it somewhere, let me see if I can find it again.
Old Jun 16, 2006 | 08:46 AM
LawlessOne's Avatar
Getting the screws out is not a problem.
I want to replace them when putting it back together.
Matching them up with something is not a big deal, but I would rather have what I need before I take everything apart.
So if someone knows the actual size and thread pitch, I'd be greatful.
Old Jun 16, 2006 | 08:57 AM
H-T Order of Merit
Default Re: (LawlessOne)
I still can't find the size, I know I saw it somewhere though. In the meantime, you could try PMing a member by the name of Maxbore.com or contact him in his thread which is linked below.
Big bore throttle bodies $100
Since he does lots of work on Honda throttle bodies, he should be able to tell you the exact thread diameter and pitch for the bolt you'll need.
Old Jun 16, 2006 | 08:58 AM
LawlessOne's Avatar
Thanks!
I know I saw it somewhere on the forums.
And thanks for the link!
Old Jun 16, 2006 | 09:02 AM
H-T Order of Merit
yep, np. Hopefully he can tell you what you need.
Old Jun 16, 2006 | 09:15 AM
Ross 2.0's Avatar
.80mm thread pitch and 5mm diameter
Old Jun 16, 2006 | 10:40 AM
H-T Order of Merit
Default Re: TPS mounting screws (MooGoCow3)
I thought M8 sounded too big.
Old Jun 17, 2006 | 06:37 PM
LawlessOne's Avatar
Thanks!
Old Jun 18, 2006 | 01:41 PM
LawlessOne's Avatar
Ok my TPS is done!
For the record, both of these sizes will replace the existing screws:
M5 x 0.80 x 12mm
10-32 x 1/2"
92integracer
Aug 18, 2008 09:36 PM
phthalo
Mar 20, 2006 10:03 AM
diluted
Jul 30, 2004 12:29 PM
B18EG6
Oct 19, 2002 05:19 PM
Leets
May 1, 2002 11:23 AM
