knock sensor have been searched but didn't find anything
ok the knock sensor that's on the h22 (buy the way i'm doing a swap) how do u wire it up to the ecu or does it have to wire up to the ecu. I have a 1996 accord ex! I would be glad to have this info. Thanks!
First of all if your going to have a poll you need to have some choices but I don't think a poll is going to be appropriate to this thread.
Also you made the same choice twice in your original question. So if you could clarify what you are asking it would be nice.
You need to use the H22 ECU, not the Accord's.
Scroll down in this thread: Guide to basic accords. There's a brief how-to there that tells you what you need to do.
The knock sensor circuit (red/blue), which isn't there on the stock F22, is added at the same break out as the oil pressure sending wire by using the pigtail from the Prelude harness. This wire connects to the subharness and then to ECU pin D3.
Refer to: http://www.sportcompactcarweb...._swap/ and go to wiring. It will help you with wiring in that pigtail.
BILLisCHILL
May 8, 2008 06:40 PM
