B20 with OBD0 Dizzy Searched!
Im am curious to know if a B18A1 OBD0 Distributor is compatible with a B20 engine. I dont want to convert to OBD0 becuase that would mean even more wiring problem which is the reason im removing the B16 anyway. I would run an obd0 PR4 ecu to with a B&M Command Flo to keep it from leaning out. I have searched but could not find a statement verifying this only that a B20 and LS are very similar except for stroke and bore. Thank you for your input.
yes, you can use a b18a distributor on a b20 head.
btw, b18a/b and b20b/z stroke are the same. only the bore is different, 81mm vs 84mm.
Thanks for the info! Do I have to alter the timing of the engine as well if I use an LS distributor? I have heard that you do but Im trying to find all this out ahead of time. Thanks.
smokez187
May 10, 2007 01:20 PM
boosted96coupe
Feb 15, 2007 12:35 PM
ForceFed Coupe
Dec 23, 2003 08:04 AM
