Air Conditioning Suddenly Stopped Working.....
Old Jun 16, 2006 | 05:37 AM
311's Avatar
311
Default Air Conditioning Suddenly Stopped Working.....
(91 Si)
Does the compressor or a/c system have fuses and/or relays?
Is there a way to check if the compressor is working properly?
My a/c worked cold as hell yesterday, and blows warm today. I find it hard to believe that it suddenly ran out of freon.
Any suggestions?
Thanks!
Old Jun 16, 2006 | 06:28 AM
311's Avatar
311
Default Re: Air Conditioning Suddenly Stopped Working..... (311)
Just checked and the compressor clutch is not engaging.
Where is the fuse/relay for this?
Old Jun 16, 2006 | 07:41 AM
Voodooboy520's Avatar
Theres only 2 fuse boxes; under the dash and under the hood.
Old Jun 16, 2006 | 07:53 AM
311's Avatar
311
Do you know where the relay is for the a/c?
Old Jun 16, 2006 | 07:55 AM
harmonator84's Avatar
Default Re: (311)
Dude it is probably the freon
9 times out of 10 thats what it is...
as far as the relay goes..idk, try looking in a haynes manual
Old Jun 16, 2006 | 09:14 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (harmonator84)
It the refrigerant level has to be REALLY low to keep the compressor from turning on. There would be serious evidence (dirty oil on the hoses/pipes/clutch) if he lost all the freon in one day. My system blows warm at the start of the season every year, but the compressor is still staying on (just needs a recharge)...
There is a compressor clutch relay on the upper radiator support. It is located between the battery & the upper radiator support (behind the headlight). There are two in that location, and I cannot remember which one is the compressor relay. They look like little black rubber rectangle boxes. They suck to work with because they are packed with waterproofing grease, and the rubber jackets tear really easy when you try to remove them (then they look shitty). If you don't have the Helms manual then I say let a professional handle it. You have to figure out which pins to jump to make the compressor clutch pop on. If you don't have the manual, how are you going to tell (especially if the clutch is dead)...
Old Jun 16, 2006 | 12:51 PM
Rex-Si's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote"> There is a compressor clutch relay on the upper radiator support. It is located between the battery & the upper radiator support (behind the headlight). There are two in that location, and I cannot remember which one is the compressor relay. They look like little black rubber rectangle boxes. They suck to work with because they are packed with waterproofing grease, and the rubber jackets tear really easy when you try to remove them (then they look shitty). If you don't have the Helms manual then I say let a professional handle it. You have to figure out which pins to jump to make the compressor clutch pop on. If you don't have the manual, how are you going to tell (especially if the clutch is dead)...</TD></TR></TABLE>
Prop's to you for helping the kid out and really giving him some useful information.
Old Jun 17, 2006 | 07:43 AM
TheRaven666's Avatar
Might be that the compressor finally went out. Mine snapped 2 bolts off in the block causing a shimmy. Hope you can fix the problem.
Old Jun 17, 2006 | 09:25 AM
Metal Typhoon's Avatar
Default Re: (TheRaven666)
i had the same problem i had just to change the fuse nder the steering wheel ! good luck
ksamsel
Acura TL, RL & ZDX
Dec 8, 2008 02:55 PM
hanson said
Jan 14, 2006 10:20 PM
delta901
Jul 17, 2005 03:15 PM
AlphaKennyWun
May 15, 2004 03:09 PM
