vtec not engaging bogs out like i'm hitting the barkes
Old Jun 15, 2006 | 09:14 PM
preppy79's Avatar
Default vtec not engaging bogs out like i'm hitting the barkes
hey i just need to know what possible problems could be causing my h22 swap to bog out like i am hitting the brakes when i hit vtec at 5500rpm. I had a check engine light come on but it was fuel system and that was the fuel regulatour and then i ran it for the day and it still wouldn't go to vtec and now the enginge light is on again, what could be my problem, oil pressure, egr, nock sensour, stock exhuast. please help me
Old Jun 15, 2006 | 10:11 PM
JDMF22B's Avatar
Default Re: vtec not engaging bogs out like i'm hitting the barkes (preppy79)
Check all your vaccuum lines and oil level / pressure. Other possibility sounds like egr needs a good cleaning
Old Jun 16, 2006 | 07:32 PM
preppy79's Avatar
kay so i have changed the egr out with my h23 egr and cleaned it out, plus the ceilanoid and tested it, checked the fuel regulatour and still nothing, vtec still won't kick on, but now i'm getting cel for code43 and not sure what to check on it
Old Jun 16, 2006 | 07:39 PM
jdmlude_dude's Avatar
Default Re: (preppy79)
could be the vtec pressue switch or vtec solenoid. did you do a swap? are you sure vtec is wired correctly? if so, are the wires connected?
Old Jun 16, 2006 | 07:48 PM
preppy79's Avatar
solenoid is fine, yes its a swap, and i don't know if the wiring was done right, would anyone have an actuall picture of the wiring done either directly to the ecu or the wireharness
Old Jun 16, 2006 | 08:39 PM
bb_one's Avatar
Sounds like it could be the wiring, double check the wiring if it's correct.
This thread should help you:
https://honda-tech.com/zerothread?id=1004852
Old Jun 16, 2006 | 09:11 PM
preppy79's Avatar
Default Re: (bb_one)
cool that really did explain it in the simpliest terms. now were could i pick up a couple of pins for the ecu harness
Old Jun 16, 2006 | 09:15 PM
bb_one's Avatar
Try a junkyard, bring a knife or pliers, slice off a connector end from any Honda ECU plug.
Old Jun 16, 2006 | 10:18 PM
preppy79's Avatar
sweet thanks it'll be my first stop in the morning. let you know how it goes tomorrow night.
Old Jun 17, 2006 | 09:30 AM
https://honda-tech.com/zerothread?id=833163
This is a wiring guide I made about 2 years ago.
Old Jun 17, 2006 | 02:46 PM
preppy79's Avatar
Default Re: (jdmlude_dude)
well i tried the pressure switch it is in perfect shape, i checked the oil pressure and it builds up enough to shot out across the room, i also took the cat off and ran it, still no vtec, but now it feels like a rev limiter kicking on, is it possible that with the switch of the h22 engine and the h23 ecu that it messed up the ecu and made a limiter come on. because before i did the swap i was able to get up past 6500rpms with out any problems its just with the h22 in there.
Old Jun 17, 2006 | 03:15 PM
AnthonyG2003
Guest
Posts: n/a
do you even have vtec wired up??
Old Jun 17, 2006 | 11:20 PM
preppy79's Avatar
well thats the thing my mech that did the swap says that he wired it and did it to the specs on the ulitimate h22 swap guide. but now i'm not to sure. is it possible that the h23 ecu sense's the oil pressure build up and kicks on a limiter to keep it from getting to high
Old Jun 18, 2006 | 07:18 AM
That is why i posted my wiring guide in here. Look at it.
Old Jun 18, 2006 | 04:16 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
well your in limp mode for one...just outta the blue does your spedominter work????? you only need 3 wires for vtec....ground, oil pressure, voltage......shouldn't be that hard to mess up???? are you using the P13 ecu??
Old Jun 18, 2006 | 04:30 PM
akstunt600's Avatar
uhmm, if your throwing code 43 that would be the idle air control valve if my memory serves me correctly, and yes that would put your car in limp mode which disables vtec fattens up the fuel and retards the timing.
get your iacv fixed that should solve your problem
Old Jun 18, 2006 | 11:21 PM
preppy79's Avatar
dang man that is some of the most useful info i have gotten yet. well just to say my ecu I think is a P14 does that tell anyone of you anything. yup the spedo works, everything seems to work fine, the cel only comes on when i have the car running at 3300rpms and seems to come on only when i'm in fifth gear on the freeway.
Modified by preppy79 at 12:48 AM 6/19/2006
Old Jun 19, 2006 | 02:26 AM
P13 is the H22 ECU......try connecting a P72 or a P28 ecu and see if vtec works then
Old Jun 19, 2006 | 07:40 AM
preppy79's Avatar
Default Re: (I got the CD5 Jeebies!)
so what are the P72 and P28 ecu and is the type of ecue on the top of the ecu in the middle of the serial numbers.
Old Jun 19, 2006 | 07:44 AM
darkspector's Avatar
well if you have a p14 h23 ecu... you're not going to have vtec
Old Jun 19, 2006 | 07:51 AM
Default Re: (darkspector)
P14 H23 ECu???/ thats not right??? is it?? i thought it was the P12 or something
Old Jun 19, 2006 | 08:09 AM
preppy79's Avatar
kay so then why are some people saying that it shouldn't matter what ecu it is you can wire them up and it would work, anyhow i will go and pick up a h22 ecu tomorrow and then let you all know what happens of course i will need to fix the idle air control valve.
Old Jun 19, 2006 | 08:23 AM
P72 is a GSR ECU
P28 is EX/SI
P13 is H22
P14 H23?? I haven't slept yet but I coulda swore it was a P12
Old Jun 19, 2006 | 07:50 PM
preppy79's Avatar
kay well if i am correct the type of ecu is in the middle of the numbers on top of it. so anyway i have my mech doing a h22 ecu swap and replacing the ideal air control valve tomorrow but it'll be a few days before i can get my lude back do to money shorted.
but i will let everyone know
Old Jun 19, 2006 | 08:21 PM
p14 is an h23 ecu.. you need a p13
