New Wiring Harness?
Old Jun 15, 2006 | 08:39 PM
AccordSleeperZzZ's Avatar
Default New Wiring Harness?
okie dokie. my frankenstein(f22/h22) project is coming along. have about 1/2 the parts bought (just got the head, intake mani. , TB, megan header, spark plugs, H2O pump. my next step is alternator / distributor/ all needed elctrical components. I know my accord is OBD1, what i need to know is with the new top end, will my current wiring harness work or do i need to get something off of a prelude? any of yunz guys who did the h22 swap/ hybrid work, all help is greatly appreciated!!!
thanks a million,
-Chris
Old Jun 15, 2006 | 09:07 PM
momstaxi's Avatar
Default Re: New Wiring Harness? (AccordSleeperZzZ)
use your original accord wire harness. modify it to work with your new setup (ie. cut, extend, etc) off the top of my head you'll need to lengthen the iat probably, lengthen the fan switch sensor located on thermostat housing, and possibly map sensor if you are using an h22 throttlebody without mapsensor mounted on it. everything else should plug in like normal. you will also need to add vtec wires if not already equipped...
Old Jun 16, 2006 | 07:09 AM
oh, ok. i've already got VTEC(f22b1) so, thats cool. but, thanks alot. really helps.
citylivin
Jul 30, 2011 12:50 PM
OneMadAccord
Nov 4, 2009 08:19 AM
90H22
Oct 15, 2002 06:47 PM
KTeller8
Sep 29, 2002 12:39 PM
